HELP!! just swapped z6 into a 93 dx... cel and codes 3, 21,22,41!!!!!
ight...i just swapped a z6 into a my 93 dx....i checked tha codes and its givin me 3 21 22 41.. wich are 3=map sensor 21=vtec solenoid valve 22= vtec oil pressure switch and 41=primary oxygen sensor if any one has n e idea of what i should check that would help a whole shyt load...thanx guys..
there was a type r motor in tha car before this..so im pretty sure tha wires are already ran...but i'll to check them again..i aint too good wit that wiring stuff...
use the map sensor plug on the firewall harness, NOT the Z6 engine harness.
Run the 2 VTEC wires from ECU,
plug in O2 sensor
plug in O2 sensor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote"> use the map sensor plug on the firewall harness, NOT the Z6 engine harness.
plug in O2 sensor</TD></TR></TABLE>
im not sure what harness im usin...tha car was already ran for vtec when i got it... ight thanx for tha help guys..i'll post back later on n tell you whats up....
damn i wish i would have posted this a lil earlier so you coulda stopped by...tha cars at my mothers house which is about 4 minutes flat from tha outerbridge crossing into staten island... oh well..shyt happens... n e ways.i checked tha codes again today after messin around wit tha map sensor...well.i still got tha code for tha map sendor..but tha code for tha vtec solenoid valve...i dint get that one earlier today..but about 20 mins ago..i forgot to take tha wire out of tha jumper..and tha codes came up again when i turned tha kay..and tha vtec solenoid valve code came up again.... this cars drivin me crazy..
Slacker93eg
Sep 12, 2012 09:48 AM
egturbo
Jun 28, 2004 05:02 PM
