Which OBD 1 Distributor(s) For B16a Head?
Old Oct 13, 2003 | 07:40 PM
Ruby Civic's Avatar
Default Which OBD 1 Distributor(s) For B16a Head?
Which OBD - 1 Distributors are correct AND fit b16a or b18c5 head?
Old Oct 13, 2003 | 10:41 PM
gamakichi77's Avatar
Default Re: Which OBD 1 Distributor(s) For B16a Head? (Ruby Civic)
its depend on your wiring ur'e using. if ur'e using OBD1 wiring, u should use OBD1 distributor. u can't use OBD0 or type r or GSR distributor. If i'm wrong, please correct me. ur ECU also must equivalent too. PR3 or PWo for OBD0, P30 for OBD1, P72 for GSR and P73 for B18C5.
Old Oct 14, 2003 | 06:53 AM
Ruby Civic's Avatar
Default Re: Which OBD 1 Distributor(s) For B16a Head? (acidburns_di)
i have obd0 wiring and am converting to obd1 with harness adapter and p28 ecu - basically to be able to get the better Hondata. so need the correct dizzy - what about the sohc vtec distributors?
Old Oct 14, 2003 | 08:42 AM
wickedEFguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruby Civic &raquo;</TD></TR><TR><TD CLASS="quote">i have obd0 wiring and am converting to obd1 with harness adapter and p28 ecu - basically to be able to get the better Hondata. so need the correct dizzy - what about the sohc vtec distributors?</TD></TR></TABLE>
B and D series are not interchangable except for a 90-91 LS Dizzy on a D16A6 since there both OBD0. If you convert to OB1 you'll need any B series OBD1 Dizzy which will work. You'll have to soder the wires to the new dizzy though and change injector clips to make it work right
Old Oct 14, 2003 | 09:49 AM
Malgerus's Avatar
I would say that a Del Sol VTEC distributor would work perfectly. It is a B16A, after all.
Old Oct 14, 2003 | 04:28 PM
Ruby Civic's Avatar
Default Re: Which OBD 1 Distributor(s) For B16a Head? (Mr. S)
hey, i heard that if you kept the injector resistor box that you did not have to monkey with the injectors (obd0)??
Old Oct 14, 2003 | 04:50 PM
hybridbmw's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">I would say that a Del Sol VTEC distributor would work perfectly. It is a B16A, after all.</TD></TR></TABLE>
Go with the OBD1 Del Sol b16a distributer.
Old Oct 14, 2003 | 07:27 PM
thid92's Avatar
can I haz?
correct. but that only goes for saturated ones or peak and hold i cant remember
Modified by thid92 at 9:02 AM 10/15/2003
efjones9
20
Dec 30, 2008 04:31 PM
yoffer
18
Dec 17, 2007 05:13 AM
91 ef hatchback
Mar 22, 2007 08:07 PM
Mefain
Feb 16, 2004 09:39 PM
