Tranny tech questions differential swapping and instals
Old Oct 13, 2003 | 07:06 PM
InspiredRacer's Avatar
Default Tranny tech questions differential swapping and instals
I need to ask the stupid question first
What differentials fit a Type R 97- Tranny I know lsd vs open
I need to know if the diff needs to be shimned when putting the ring gear on or bearings.
all help is appreciated
Old Oct 14, 2003 | 04:58 AM
PupaScoopa's Avatar
Default Re: Tranny tech questions differential swapping and instals (InspiredRacer)
Do you have an ITR and want to find another LSD? Anything out of a B-series hydraulic transmission should work. Use the bearings that are made for the particular transmission, not the ones that are made for the diff. Ex: Don't buy ITR bearings if you're putting an ITR diff into a S4C (99 Si) box. I learned the hard way on that one
Yes, every time you change the diff/bearings it much be shimmed. It's not too bad, just waiting for the shims to be ordered is a pain. Most dealerships can get them within a day or two though.
Old Oct 14, 2003 | 10:02 AM
Default Re: Tranny tech questions differential swapping and instals (PupaScoopa)
anybody have a how to page. I've pulled tranny's apart before I just have zero experience shimming diffs
samuraijackass
Transmission & Drivetrain
22
Feb 21, 2011 09:15 PM
Ninja Mike
Mar 29, 2006 08:31 PM
mingchi69
Feb 17, 2004 09:39 AM
BoostedAcura
Sep 6, 2002 12:13 AM
cr00klyn718
Apr 28, 2002 03:38 AM
