Code 16 HELP!!!!!!!!!!!!!!!!!!
Old Aug 31, 2001 | 12:46 AM
Turbohatch's Avatar
New User
Default Code 16 HELP!!!!!!!!!!!!!!!!!!
im throwing code 16 is my fuel injectors bad or is there a problem in the wiring any pics or info to fix.....thanks
Old Aug 31, 2001 | 05:27 PM
fixhondas's Avatar
Default Re: Code 16 HELP!!!!!!!!!!!!!!!!!! (Teken)
what make year model?
Code 16 only indicates a circuit problem with the injectors- that is all. Most likely a main relay. An injector that is sticking will NOT cause this code- only an open circuit or excessive resistance will throw a code 16.
Old Sep 1, 2001 | 12:48 AM
Turbohatch's Avatar
New User
Default Re: Code 16 HELP!!!!!!!!!!!!!!!!!! (fixhondas)
it is on a b16 with fmax turbo only booasting 5 psi
Old Sep 1, 2001 | 12:49 AM
Turbohatch's Avatar
New User
Default Re: Code 16 HELP!!!!!!!!!!!!!!!!!! (Turbohatch)
where is the circuit relay located to the injectors??????????
Old Sep 1, 2001 | 05:30 AM
fixhondas's Avatar
resister pack is part of the circuit (if applicable) and this can give a 16. If the thing runs fine and this code is intermittent- it is most likely a main relay (providing your wiring/harness is reliable). The relay is located on the driver's side above the hood cable pull. (88-95 civics)
Old Sep 3, 2001 | 08:16 PM
Turbohatch's Avatar
New User
if i bought new injectors would that fix the problem codes
Old Sep 4, 2001 | 03:08 PM
Turbohatch's Avatar
New User
[Modified by Turbohatch, 12:09 AM 9/5/2001]
Old Sep 4, 2001 | 03:38 PM
Turbohatch's Avatar
New User
could it be that im running to much boost and the injectors cant handle the load (stock gsr injectors) but when im only running 5 pounds at high rpms it throws the code
ExtraBlackRex
Oct 28, 2010 05:18 PM
H22Ej1
Jan 23, 2009 10:35 AM
MUGEN_EG95
Sep 3, 2008 08:57 PM
raiden571
May 18, 2005 10:54 AM
delux247
Jan 28, 2004 11:48 AM
