Code 16....
Old 10-28-2010 | 05:06 PM
ExtraBlackRex's Avatar
Default Code 16....
Ok so i've been doing some reading as for the reasons why a car would throw this signal out there.
The Code 16 represents an injector problem, however, many people say that the main relay could be the culprit, as it controls the firing of injectors and THUS will trigger an injector related code if it's going out or bad.
However I know that a BAD main relay won't allow the car to start...MINE does start but will run in limp mode. Could I have just ran the wiring in the wrong order when I did my MPFI conversion??? Could my resistor box be going?? Or can the Main Relay cause this, if it's GOING BAD, and still allow the car to run (I have very little problem starting the car)...
Any help would be appreciated.
Old 10-28-2010 | 05:18 PM
Default Re: Code 16....
ALSO...I have a noticible leak around one of my injectors, would it be safe to say that a leak of sufficient magnitude throw me in Limp Mode and draw out a code 16??? (I'm thinking fuel pressure drop via leak...)
dacrxguy
11-19-2008 07:31 PM
Rease3
03-15-2008 09:57 AM
SupraRXZ
04-06-2006 09:48 AM
pokemon
07-26-2003 09:24 AM
typegsr
04-30-2003 05:01 PM
Quick Reply: Code 16....
