Removing check engine light/bulb from dash
Old Oct 13, 2003 | 05:33 PM
udm_motorsport's Avatar
Default Removing check engine light/bulb from dash
Hi
I recently did a ZC swap to my Civic Si 1990.
By doing this, the check engine light is always on, and i cannot pass emissions with it on.
I was told to remove the bulb, but i dunno where to start. Any ideas as to how i can get rid of the light?
Thanks
Franklin
Old Oct 13, 2003 | 07:29 PM
Rossifumi's Avatar
Default Re: Removing check engine light/bulb from dash (to_carpediem)
reset ecu disconnect neg side wait 10-15 seconds reconnect should go out.
Old Oct 13, 2003 | 07:31 PM
jeff652's Avatar
The smog station checks the CEL for proper functionality. Notice it turns on for 5-8 seconds when you start the car . . .
It does that for a reson ;-)
Old Oct 13, 2003 | 08:26 PM
MrHeeltoe's Avatar
Ever try to figure out what was wrong with it and, oh, say, fix it?
Old Oct 14, 2003 | 04:39 AM
Default Re: Removing check engine light/bulb from dash (MrHeeltoe)
Actually, reading alot of the ZC swaps, since we have to splice a couple of wires and rewire the distributor, they said the check engine light will be on all the time.
I reset the ecu, but that didnt work either. So i figured i'd just remove the bulb so i can get the car inspected.
Thanks
Franklin
Old Oct 14, 2003 | 07:08 AM
MrHeeltoe's Avatar
That is BS. I had two ZCs in Two different cars and never had a light or a problem.
Sounds like you need to fix some wiring or something.
Old Oct 14, 2003 | 07:26 AM
PhatOptimo's Avatar
What CODE is it flashing?
Old Oct 14, 2003 | 08:04 AM
sleepyEK's Avatar
Default Re: Removing check engine light/bulb from dash (PhatOptimo)
yeah, i have never seen a cel on a zc swap. you wired some **** wrong. go through your wiring harness.
Old Oct 14, 2003 | 08:21 AM
wickedEFguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatOptimo &raquo;</TD></TR><TR><TD CLASS="quote">What CODE is it flashing?</TD></TR></TABLE>
BUMP, Again check your codes man
Old Oct 14, 2003 | 11:22 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by to_carpediem &raquo;</TD></TR><TR><TD CLASS="quote">Hi
Thanks
Franklin</TD></TR></TABLE>
*shakes head*
why the hell would you wanna do that?!?
That's not gonna solve your problems in passing emissions at all.
Even though you'd remove the check light, your car is still going to be running in limp mode.
Find out what code is being thrown; report back so we can help.
Old Oct 14, 2003 | 11:57 AM
1bad-eg's Avatar
FIX YOUR CEL
Old Oct 14, 2003 | 12:01 PM
Default Re: Removing check engine light/bulb from dash (1bad-eg)
OK, so how do i check the codes?
I'm very new to the civic and know not much.
I do have the integra ecu too.
Thanks
Franklin
Old Oct 14, 2003 | 01:21 PM
PhatOptimo's Avatar
http://www.c-speedracing.com/faq/06.php
You don't need a paper clip like it says. Skip that part. Out cars don't have that blue connector.Turn the key to the on position and count the ECU light flashes. The ECU is under the passenger footwell carpet.
The code list is here
http://tech.hybridgarage.com/tech/codes.html
90dteg
Sep 18, 2008 12:54 PM
PIC Performance
Jun 12, 2006 10:37 PM
escape2me
Jan 25, 2005 02:16 PM
andrew dc
Aug 18, 2001 03:40 AM
under_psi
Aug 16, 2001 12:50 PM
