Does anyone have the Field Vtec Controller Instructions in English??
Does anyone have the Field Vtec Controller Instructions in English?? Or does anyone know what the is the code for the switches on the back of the vtec controller for a B18C1? Also what settings do those of you that have it use? All I have is intake and header. What do you think are good settings? Sorry, no I can't get to a dyno.
meh.. the field was fun to play with.
Oh also the wiring diagram is different on a teg then a prelude which is used
in that link above as an example.
I only have a diagram for 00 ITR so if anyone has 95 gsr diagram please
post it.
post it.
Thanks for the link. I know I shouldn't be using it without dynoing it. I ran it for 60k miles on my old car without dynoing it. The settings were all at zero though. It ran much better with it than without. I had a 89 civic hb with a D16Z6 (SOHC VTEC) all pre-OBD stuff. Just adjusted the vtec settings. Anyone use a field or even a vafc on a pretty much stock B18C1?
evilhatch2.0
Feb 17, 2004 03:59 PM
