alternator noise!!!
Old Oct 13, 2003 | 04:38 PM
MrEg's Avatar
Default alternator noise!!!
just installed a new belt and the alternator is now screaming........i loosened it a bit until the noise went away but now the belt is too loose.......any ideas
do i need to lube the alternator
Old Oct 13, 2003 | 04:49 PM
sleepyEK's Avatar
Default Re: alternator noise!!! (mr_timluu)
do you have the right belt on it? i don't see why your alternator bearings would start making noise just from changing the belt. adjust your belt so that when you can only twist the belt about 90 degrees.
Old Oct 14, 2003 | 04:05 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_timluu &raquo;</TD></TR><TR><TD CLASS="quote">...i loosened it a bit until the noise went away but now the belt is too loose...</TD></TR></TABLE>Why do you think it's too loose? If it doesn't slip when lights & stuff are turned on, then it's not too loose.
Old Oct 14, 2003 | 02:53 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
try a putting on a little belt dressing..
Old Oct 14, 2003 | 11:19 PM
MrEg's Avatar
didnt help......any other ideas...
Old Oct 14, 2003 | 11:28 PM
99blackcivicSi's Avatar
Default Re: (mr_timluu)
I wish honda put an acual tensioner on the alternator instead of the arm tensioner.
Loosen it agian to where you had it where the noise stopped and then try tightening it little by little till you get that point right where it wants to make noise but doesn't it is a really big pain in the *** but worth a try
Old Oct 15, 2003 | 01:13 AM
MrEg's Avatar
Default Re: (99blackcivicSi)
im trying that ...its seems like its working...........its kind of the mind set thing of worry if its not tight enough u know
Old Oct 15, 2003 | 03:58 AM
JimBlake's Avatar
Maybe it's been too tight for a long time & the alternator bearings are beginning to suffer...
Old Oct 15, 2003 | 08:35 AM
MrEg's Avatar
i just installed the belt...the car hasnt even been driven on the road cuz im afraid of recharging system failure.....
Old Oct 15, 2003 | 08:36 AM
MrEg's Avatar
i tried this on b series 4 alternators on my 1 car......and they all make noise...so i think its cuz its too tight......how do you check it its recharging...which wires do i test
Old Oct 15, 2003 | 08:42 AM
mmuller's Avatar
Mad Scientist
read the manual, think you put them too tight, with the car running check voltage to the battery; it should be around 14.4 if im not mistaken
GSRpoweredSI
Jun 20, 2007 01:13 PM
Maretron
Jul 29, 2005 03:54 PM
