01 type R oil pump on 94 gsr block....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbanracer98 »</TD></TR><TR><TD CLASS="quote">the type r oil pump will work fine on any b series motor. it's actually a good buy because it has a high flow gear in it.
Exactly!
</TD></TR></TABLE>Exactly!
is i possible to use this same itr pump or gsr pump in place of ls pump building ls'vtec
i know i will have to use a vtec timing belt if i have a b16 head b18b bottom end can the vtec parts don't i use a vtec timing belt ???????/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScootinIntegra »</TD></TR><TR><TD CLASS="quote">almost the same as above...i'm getting a B20B and turbo, oil cooler, and i was looking at getting a ITR oil pump...will this work, or be beneficial?</TD></TR></TABLE>
the R pump will work fine four your app.
Enough said on the subject, the first two to three posts were enough. The question asked could have been answered by itself, Type R oil pump on a GSR block, hmmmmmmmmmm an exact fit higher flow oil pump (B-series VTEC) on a GSR block(B-series VTEC)?hint, hint..... You make the call, and do a search next time you may just answer your question befor resorting to posting.
Hey Gerard....
Calm your *** down dude....if you knew so much than you should have said something before....AND it is NOT a direct fit since you have to buy the 01 R timing cover because the outline of the pump is different than a GSR pump.....chill man and stop whining.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PainfulTeg »</TD></TR><TR><TD CLASS="quote">Hey Gerard....
Calm your *** down dude....if you knew so much than you should have said something before....AND it is NOT a direct fit since you have to buy the 01 R timing cover because the outline of the pump is different than a GSR pump.....chill man and stop whining.</TD></TR></TABLE>
yeah dude.....chill out.....
Are you 100% sure about that timing cover thing ? I put an ITR oil pump on my 98 LS and my plastic covers went on just fine.
so 96 + oil pump from a gsr or itr pump are interchangable for and ls with no mods to the oil pump does the same hold true for the crv fuel pump and water pump i went to advanced auto parts and they were the same part number for the fuel pump they look identical to i ask because the acura parts cost more than the honda ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 »</TD></TR><TR><TD CLASS="quote">96+ Integras have a CFK sensor that 94-95 don't have. So, the covers are different.</TD></TR></TABLE>
^ Correct.....or you could modify the 94-95 and make it fit.
GSR/SI/Type-R oil pumps are the same, will fit LS and CRV.
LS and CRV water pumps are the same, different from the VTEC pumps.
The fuel pump doesn't matter, hell a Mitsubishi 3000GT VR-4 AWD twin-turbo fuel pump fits........it's all about how much flow you need.
thanks so your saying 99 civic si and 96 +del sol vtec pumps ie water pump, fuel and oil will fit on ls . i only asking cause i don't want to order ne thing that won't fit / i 've had heard about the the fuel pump a mechanic also told me how to take mitsubishi 400cc injectors and put it in a integra so your right on the flow
