Motor install help
Old Oct 13, 2003 | 02:57 PM
tub_sephiroth's Avatar
Default Motor install help
My cousin and I installed a used motor into the accord. The motor cranks but won't turnover. All 4 cylinders all sparks going into it. Sometimes, it would turnover for about 2 seconds then die. Compression numbers:
Cylinder 1: 180
Cylinder 2: 155
Cylinder 3: 160
Cylinder 4: 180
Old Oct 13, 2003 | 08:51 PM
rsmotors's Avatar
Default Re: Motor install help (tub_sephiroth)
when you say crank, thats the same as turn over.
you mean won't fire up. check you firing order. check timing. check for fuel
Old Oct 13, 2003 | 09:12 PM
Default Re: Motor install help (rsmotors)
Yeah, sorry. That's what I meant. I took off the distrubitor to put on the new motor but never took out the plugs on the cap so they should be in order. There should be fuel. I forgot to hook up the fuel line and when I connected the battery, fuel dripped all over the driveway. Will have to check timing again.
Old Oct 13, 2003 | 10:11 PM
muse's Avatar
I don't know if this will help, but whenever we do a swap, right before we start, we make sure and prime the fuel system a couple of times to make sure theres plenty of fuel.
Also, check ALL of your grounds. That's usually the won't start culprit.
Old Oct 14, 2003 | 05:41 AM
Default Re: Motor install help (muse)
How many different grounds are there?
Tranny, motor, thermostat....
Old Oct 15, 2003 | 07:57 PM
You think it could be the timing?
Old Oct 15, 2003 | 09:24 PM
chrisCNL's Avatar
any code from the ECU.
Old Oct 15, 2003 | 10:40 PM
mmuller's Avatar
Mad Scientist
Default Re: Motor install help (chrisCNL)
check ignitor too
Old Oct 16, 2003 | 07:52 AM
Default Re: Motor install help (mmuller)
No codes. I don't think it's the ignitor seeing that I've got sparks coming from all spark plug wires.
Lokisdope
Aug 5, 2008 03:14 AM
itr1244
Jun 20, 2006 03:23 PM
turbocivic0618
Nov 24, 2005 08:20 AM
krazie1
Oct 29, 2003 10:58 AM
