Piston Ring End-Gap...Is This Right?
Old Oct 13, 2003 | 02:25 PM
LudeyKrus's Avatar
Default Piston Ring End-Gap...Is This Right?
At here:
http://www.icelord.net/honda/repair/
It says this:
"Rings
No. 1
End Gap
Standard ........................... .010-.014 (.25-.35)
Service Limit ............................... .024 (.60)
Side Clearance
Standard ....................... .0014-.0024 (.035-.060)
Service Limit ............................... .005 (.13)
No. 2
End Gap
Standard ........................... .024-.030 (.60-.75)
Service Limit ............................... .028 (.90)
Side Clearance
Standard ....................... .0014-.0022 (.035-.055)
No. 3 (Oil)
End Gap (3)
Standard ........................... .008-.020 (.20-.50)
Service Limit (3) ........................... .024 (.60)
End Gap (4)
Standard ........................... .008-.028 (.20-.70)
Service Limit (4) ........................... .031 (.80)"
Ring #1 is top compression ring, #2 is next comp. ring, #3 is the ridged oil ring, and #4 is the top and bottom oil ring, right?
Old Oct 13, 2003 | 03:57 PM
aeolus's Avatar
Default Re: Piston Ring End-Gap...Is This Right? (LudeyKrus)
this looks like it came out my prelude helms.i rememebr those specs when i rebuilt my first block.
Old Oct 13, 2003 | 04:57 PM
LudeyKrus's Avatar
Default Re: Piston Ring End-Gap...Is This Right? (aeolus)
so does that sound right? I wanna make sure i'm settin the right ring's gap
Old Oct 13, 2003 | 10:52 PM
aeolus's Avatar
as long as your block was honed to specs,the stock rings should not need any filing,but yeah,thats right.
Old Oct 14, 2003 | 07:32 AM
T4eg's Avatar
those specs sound right to me
Old Oct 14, 2003 | 08:07 AM
LudeyKrus's Avatar
alrighty, think i found out for sure;
#1 is top comp. ring,
#2 is 2nd comp. ring
#3 is top and bottom oil ring,
and the accordion-looking ring ya don't screw with.
Thanks for the help!
Old Jun 20, 2004 | 02:55 AM
93H22ACX's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">alrighty, think i found out for sure;
Thanks for the help!</TD></TR></TABLE>
so what did you end up gapping your rings to?
MigsD16
Engine Machining & Assembly
12
Sep 20, 2016 12:33 PM
ef-b16sedan
Jul 20, 2010 09:33 PM
KURUPTinc
Aug 25, 2007 12:24 PM
KooK
Feb 4, 2006 09:08 PM
