99-00 wiring conversion and differences
Old Oct 13, 2003 | 06:07 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default 99-00 wiring conversion and differences
ok another first. this is the first 99-00 b16 swap for me. i have a jdm GSR. i have a p72 with an obd2.1-obd2.2 converswion harness already. i know about pretty much everything except the distributor. the 00 dx has 8 wires. the GSR has 8 or 9 but they have the 12ga + - for the coil. basically the plugs are too different to repin. any suggestions? last case scenerio is a 99-00 Si engine harness but thats 395 and im not ready to spend that yet. i did a search but nothing for the 99-00. TIA.
Old Oct 13, 2003 | 11:21 AM
Mr. Badwrench
Default Re: 99-00 wiring conversion and differences (boostedcivicsir)
bump please
Old Oct 13, 2003 | 11:47 AM
Scotty B's Avatar
I am pretty sure you cut the plug off the dist. side on the motor and match the colors to the plug off the original motor... I could be wrong, but take a look and see if that makes sense?
Old Oct 13, 2003 | 12:24 PM
Mr. Badwrench
Default Re: 99-00 wiring conversion and differences (nasi)
it does but there is 1 or 2 more wires kinda like a dx swap in a 88-91 but i know where they go.
Old Oct 13, 2003 | 12:54 PM
dantastic's Avatar
what car is this going into? what motor is being put in? and which harness are u using?
Old Oct 13, 2003 | 05:57 PM
Mr. Badwrench
Default Re: (dantastic)
JDM gsr obd2
p72 ecu but i have a 2.2-2.1 adapter.
goin in a 00 dx.
i think i got it but i am lost on the big black and yellow wire. i think it is just a switched 12 volt as the positive for the coil?
i have a helms and am getting closer. i have so much **** on my mind right now i need a few clearer heads.
Old Oct 14, 2003 | 07:49 PM
Mr. Badwrench
bump? anything new? i think i may have it but i need a clearer head to help.
boomersz
Mar 4, 2007 01:11 AM
boomersz
17
Mar 3, 2007 07:25 PM
JDM Approved
Nov 10, 2004 03:21 PM
420aNT
Dec 24, 2003 10:12 PM
