Need Help rebuilding H22a block
Old Oct 12, 2003 | 10:19 PM
Showoff's Avatar
Default Need Help rebuilding H22a block
Its a 1994 JDM H22A block -these are my plans Crower Billet Rods, JE Pistons Bore 3.425-Stroke 3.571-Rod length 5.63- Compression ratio 9.0:1 and
Golden Eagle sleeves (going Turbo) what other parts consists in the block other then seals ? that i missing to put in ? should i over bore the block ? stock i belive is 86-87mm ? should i bump it up ? anyone list any companys that u might think that would work better if so
Old Oct 12, 2003 | 11:25 PM
satan_srv's Avatar
Default Re: Need Help rebuilding H22a block (Showoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Showoff &raquo;</TD></TR><TR><TD CLASS="quote">Its a 1994 JDM H22A block -these are my plans Crower Billet Rods, JE Pistons Bore 3.425-Stroke 3.571-Rod length 5.63- Compression ratio 9.0:1 and
Golden Eagle sleeves (going Turbo) what other parts consists in the block other then seals ? that i missing to put in ? should i over bore the block ? stock i belive is 86-87mm ? should i bump it up ? anyone list any companys that u might think that would work better if so </TD></TR></TABLE>
You're going turbo, so I don't know if boring out the sleeves much beyond 87 is necessary, is that extra displacement worth it, or would you rather have a thicker sleeve?
I'm all motor at 89mm which is fine, and is likely fine for turbo too, it's more about preference. You need to get the bottomend gasket kit, and new bearings too (well if they show any wear). New oil pump if you think it needs it.
Old Oct 13, 2003 | 08:57 AM
fastludeh22's Avatar
Default Re: Need Help rebuilding H22a block (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
...and new bearings too (well if they show any wear)... </TD></TR></TABLE>
i thought anytime you open it up, you need to put new bearings in. i have a h22 w/2k on it. im about to upgrade the rods, so if the bearings look good, i dont have top try and find the right ones again?!
Old Oct 13, 2003 | 09:42 AM
SKDRCR's Avatar
Default Re: Need Help rebuilding H22a block (fastludeh22)
oil pump pro drive gear
Old Oct 13, 2003 | 11:08 AM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">
i thought anytime you open it up, you need to put new bearings in. i have a h22 w/2k on it. im about to upgrade the rods, so if the bearings look good, i dont have top try and find the right ones again?!</TD></TR></TABLE>
If you are changing something yeah you have to, sorry I was thinking of a stock bottom end (on crack last night)
Old Oct 13, 2003 | 11:35 AM
SKDRCR's Avatar
speaking of crack did you put another knife-edge crank
in your ride or do you just have a stock one
If you are changing something yeah you have to, sorry I was thinking of a stock bottom end (on crack last night)</TD></TR></TABLE>
im still a little confused. if its stock you dont have to change them? ie- the main bearings?
Old Oct 14, 2003 | 08:38 AM
Showoff's Avatar
Default Re: Need Help rebuilding H22a block (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">oil pump pro drive gear
</TD></TR></TABLE> forgot about that Je Pistons 9.0:1 or 10.0:1 Je psitons ? now that is the question ? anyone
Old Oct 14, 2003 | 08:56 AM
H22Si's Avatar
I'd say keep it at 9.0:1 for easier tuning and a longer life. Make up for the lack of compression with more boost
Old Oct 14, 2003 | 09:02 AM
H22Si's Avatar
Default Re: Need Help rebuilding H22a block (H22Si)
Better worded, let the increased boost make your cylinder pressure.
Old Oct 14, 2003 | 09:03 AM
Showoff's Avatar
thats an choice giving me hard time on making 9.0:1 i know to drop it so boost more but i dont want the car to run funny...an 10.0:1 flat top pistons then run little finner...car is gonna be most for street's use in the weekend's then a car for the track MmMM......
Old Oct 14, 2003 | 09:12 AM
SKDRCR's Avatar
I would still go 9.0:1
Old Oct 14, 2003 | 10:51 AM
see_our_vtec's Avatar
9.0 or 9.5
Old Oct 14, 2003 | 06:07 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">speaking of crack did you put another knife-edge crank
in your ride or do you just have a stock one </TD></TR></TABLE>
stock. The crank spins up to speed fast enough already
Old Oct 15, 2003 | 09:37 PM
civicsitek GanGsTa's Avatar
Id run the 10:1 for a the quicker spool it will give you.
Old Oct 15, 2003 | 10:36 PM
Showoff's Avatar
Default Re: Need Help rebuilding H22a block (civicsitek)
the thing is should i get flat headed pistons ? an 10.0:1 ? or an 9.0:1 ? i would like to boost up to 22 with race fuel..and i really not going ot take the car to an race track all the time maybe rare...more of it on the streets on weekend at night and highway races more likely...so an 9.0:1 and an T60-2 turbo or an 10.0:1 and a T3/T4 turbo ? the following most likely will be my..
fuel and mgmt system
RC Engineering 720CC injectors or 780's . AEM Fuel Rail, AEM FPR and a high flow pump
ECU
Hondata S200 System
P28 OBD 1 ECU
Motec 3 bar Map sensor
Old Oct 16, 2003 | 01:58 PM
H22Si's Avatar
with those goals, deffinately 9.0:1
F2BTorQ
Mar 27, 2012 09:29 PM
superfast666
Jul 9, 2008 07:41 AM
McLude2nRR
Oct 20, 2005 11:34 AM
djnikko
Jun 16, 2005 04:23 AM
Showoff
Oct 16, 2003 07:05 AM
