rear sway bar for g2?
Old Oct 12, 2003 | 08:18 PM
crooked muffler's Avatar
Default rear sway bar for g2?
susp. tech. rear sway bar
worth it?
and does it have mounting brackets for ease of installation...
thanks
Old Oct 12, 2003 | 08:40 PM
Slain's Avatar
alot of people run this set up. def worth it. If you want to pay a little more to run a 22 mm rear sway get the progressive one.
Old Oct 12, 2003 | 08:41 PM
VTECorona's Avatar
Default Re: (Slain)
Lotsa people on h-t use the ITR rear sway and swear by it. I'm gonna buy one soon along with the beaks or bsq reinforcement kit
Old Oct 13, 2003 | 09:38 PM
Slain's Avatar
for a gen 2 integra i dont think the itr rear bar is a bolt in. i've seen a member on g2ic battlecat do this conversion with some additonal mods. imo go with the progressive
Old Oct 14, 2003 | 06:43 AM
VTECorona's Avatar
Default Re: (Slain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slain &raquo;</TD></TR><TR><TD CLASS="quote">for a gen 2 integra i dont think the itr rear bar is a bolt in. i've seen a member on g2ic battlecat do this conversion with some additonal mods. imo go with the progressive</TD></TR></TABLE>
You're probably right, I just realized it said g2 in the subject
Old Oct 19, 2003 | 08:33 PM
Default Re: (Slain)
IM gonna go with the progress too...
wheres the cheapest place uve seen to order?
Old Oct 20, 2003 | 10:21 AM
Slain's Avatar
i've seen em go for around 150-200 just for the rear. dont know any links off hand because i'm at school. I'll check back later when I get home tonight.
Old Oct 20, 2003 | 11:04 AM
xSCTYGx's Avatar
Default Re: (Slain)
what kinds of mods do u have to get in order to install that ITR rear sway? too complicated to do, is it worth it or should i just go with susp tech?
Old Oct 20, 2003 | 11:30 AM
Slain's Avatar
go to http://www.g2ic.com and look for member battlecat he succesfully did this. I'm a simple guy so the the sus tech sway would be the easiest
Old Oct 20, 2003 | 12:11 PM
EdoMoto's Avatar
Default Re: rear sway bar for g2? (anti-ricecake)
I also put a 22mm typeR rear swaybar on my 92 teg. It was much simpler than i tought. When i figured out how to do it. Will get some pics up soon. Suspension tecniques front and rear swaybars for sale. Make offers will let it go for really cheap.
mish__
Suspension & Brakes
May 27, 2011 09:08 PM
Team RS2
May 5, 2007 01:24 PM
triple
May 23, 2006 03:45 AM
HybridIntegra
20
Nov 16, 2004 07:38 PM
B_CRUZ!
Jul 9, 2003 05:35 AM
