NEED HELP WITH A HEAD SWAP
Old Oct 12, 2003 | 07:50 PM
tbocrx's Avatar
Default NEED HELP WITH A HEAD SWAP
I need help on a head swap.....head/intake manifold is from a 99 SI.....car is a 97 GSR.....what do i need to do to have the head running without any CEL....are thereand sensor swaps i will need to do?...thanks for any replies
Old Oct 12, 2003 | 08:33 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: NEED HELP WITH A HEAD SWAP (tbocrx)
IAB's will throw a code, since the B16 doesn't have them
Old Oct 13, 2003 | 01:15 AM
p3s7's Avatar
Default Re: NEED HELP WITH A HEAD SWAP (Emerika)
how is it you fix that then? I'm looking to put a b16 head on a b18c block and can't figure out which ecu to use..?
Old Oct 13, 2003 | 10:30 AM
tbocrx's Avatar
Default Re: NEED HELP WITH A HEAD SWAP (p3s7)
can i add iab to the si head...or how can i disable it so there is no code?
Old Oct 13, 2003 | 10:46 AM
Kataku2K3's Avatar
You'll be fine, and the only thing that is a little different will be the wiring harness... IAB's don't have a CEL so you don't need to worry about that... As I said it's just little things about how the GSR harness is routed as apose to the 1999-2000 Si PR3 cylinder head... Everything is plug and play besides the intake air temperature sensor (IAT)... The GSR IN manifold has a plenum mounted IAT where as the 1999-2000 Si has theirs mounted in the intake tube... You have a few options here and it's really not that big of a deal... #1, tap the IN manifold in the factory runner location and run the GSR's IAT... #2, pull it out of the GSR IN manifold plug it in and leave it... #3, get ahold of a DOHC VTEC Del Sol IN manifold... Lastly, take an IAT and connector off of a 1999-2000 Si, cut the stock GSR round style connector off and solder on the new one (porarity doesn't matter here), and plug it into your intake tube just how it is on the Si's... Just my $0.02 and I hope this helps... Peace
EDIT: Just for your information, since it doesn't throw a CEL you don't have to worry about it but the IAB's can't go in any other IN manifold then that of the H22 and B18C1...
Old Oct 13, 2003 | 11:39 AM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default Re: NEED HELP WITH A HEAD SWAP (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">You'll be fine, and the only thing that is a little different will be the wiring harness... IAB's don't have a CEL so you don't need to worry about that... As I said it's just little things about how the GSR harness is routed as apose to the 1999-2000 Si PR3 cylinder head... Everything is plug and play besides the intake air temperature sensor (IAT)... The GSR IN manifold has a plenum mounted IAT where as the 1999-2000 Si has theirs mounted in the intake tube... You have a few options here and it's really not that big of a deal... #1, tap the IN manifold in the factory runner location and run the GSR's IAT... #2, pull it out of the GSR IN manifold plug it in and leave it... #3, get ahold of a DOHC VTEC Del Sol IN manifold... Lastly, take an IAT and connector off of a 1999-2000 Si, cut the stock GSR round style connector off and solder on the new one (porarity doesn't matter here), and plug it into your intake tube just how it is on the Si's... Just my $0.02 and I hope this helps... Peace
EDIT: Just for your information, since it doesn't throw a CEL you don't have to worry about it but the IAB's can't go in any other IN manifold then that of the H22 and B18C1... </TD></TR></TABLE>
wow this guy knows hes **** . could not have said it better than that
speedworkzb18
Nov 11, 2004 11:19 PM
civic_freak
Jul 1, 2004 04:47 PM
TeamDOHCside
May 31, 2004 09:12 PM
HaTcH_BmX
11
Nov 4, 2003 04:08 PM
1.8T_EG
Oct 21, 2002 08:53 AM
