test pipe problems!! help
Old Oct 12, 2003 | 05:29 PM
SsTiNgEr77's Avatar
Default test pipe problems!! help
1st off- i hate the way it sounds and im going to put on the cat next weekend, but
for now i have to live with it...basically my car is bogging at low rpms? BTW - with the test pipe i installed a greddy evo catback, yet i think that this problem is irrelevant to the bogging.
ok, installed test pipe couple days ago for my 98 obd2 prelude.. pipe was 2.5 and has nut welded on top for o2 sensor..
after install the car ran fine and nothing was wrong.. no CEL no problems at idle...After driving the car for a couple hours the CEL came on the freeway...
Yesterday im trying to take the test pipe off and the damn exhaust bolts just wont budge so im going to wait till my friend and i can use his air tools to zing them off..or just drill them off..
but after the failed attempt to put the cat back on the 1st time...i decided to reset the ecu so i took out the clock fuse?? ( is that even correct? ) and let it sit for about 15 minutes...starting my car back up with the pipe installed is causing the car to just bog at low rpms...in neutral if i rev to 3k, then it'll just go down to around 200..100 rpms and 30% of the time just die... i assumed the car was just remapping because i let it sit for about 8 minutes and the car ran fine..no CEL no problems...
today while driving i noticed the car was doing the bogging low rpm problem again? what can i do to stop this until i put the cat back on?
im thinking of a resistor or some other jerry rigging ideas.. but im sure h-t has a better idea?
Old Oct 12, 2003 | 07:34 PM
AnNiMosSiTY's Avatar
Default Re: test pipe problems!! help (SsTiNgEr77)
wrong forum homie ^_^
hit me up on ICQ
Old Oct 12, 2003 | 08:36 PM
SsTiNgEr77's Avatar
rofl sup, spend like 2 hours trying to get the test pipe off and i couldn't.. so i put it back on lol...
i reset the ecu and it started acting all gay... but no CEL, it didn't run a cel though for like 3 hours... but now the CEL is on and car is being all gay after the reset :\
Old Oct 12, 2003 | 09:24 PM
Default Re: (SsTiNgEr77)
It aint worth the extra 2-4 hp just come back over and we'll put your cat back on.
Old Oct 12, 2003 | 09:57 PM
SsTiNgEr77's Avatar
sounds good bro, imma try to attack it myself 2...i've read up on lot of things and i'll try a bit more stuff to fix it... ttyl
SsTiNgEr77
Oct 13, 2003 09:52 PM
SsTiNgEr77
Oct 12, 2003 09:51 PM
SsTiNgEr77
Oct 12, 2003 07:32 PM
SsTiNgEr77
Oct 12, 2003 05:31 PM
