how to install external coil?
Old Oct 12, 2003 | 03:36 PM
xci_ed6's Avatar
Default how to install external coil?
thanks
I searched.
-Dustin
Old Oct 12, 2003 | 07:58 PM
xci_ed6's Avatar
Default Re: how to install external coil? (krustindumm)
I am looking for how to modify the cap and how to wire up the coil.
TIA
-Dustin
Old Oct 12, 2003 | 09:18 PM
91civicDXdude's Avatar
how to wire up the coil is easy. remove the wires from the coil marked + and - and extend them to the external coil's + and -
as for the cap, just buy an MSD modified cap.
Old Oct 13, 2003 | 01:59 PM
Donkey85's Avatar
Default Re: (91civicDXdude)
could you run the factory coil with an external coil as well to get a hotter spark?
Old Oct 13, 2003 | 02:02 PM
xci_ed6's Avatar
Default Re: (Donkey85)
no, but you can get a high voltage aftermarket coil and move alot of heat out of the distibutor.
-Dustin
Old Oct 13, 2003 | 09:12 PM
Donkey85's Avatar
Default Re: (krustindumm)
how would you go about modifying the dist to take the stock coil out? you would most likely have to get the msd cap set up for it already i take it? is there really that much heat in the dist with the stock coil in there? Would you notice a difference with changing over to a higher voltage coil?
Old Oct 13, 2003 | 10:17 PM
xci_ed6's Avatar
IDK, but I will be testing to find out. The MSD cap is just a modified stock cap, so yeah you can modify it yourself. With the coil disconected it will create no heat.
-Dustin
Old Oct 14, 2003 | 07:49 AM
redzcstandardhatch's Avatar
something different
supposedly old accord caps work fine as external coil caps for d series motors, i have an msd cap and love it. just run the wires for pos. and neg. to the external coil and fire that hoe up........worked good for me for the last 15,000 miles.
Old Oct 14, 2003 | 08:42 AM
xci_ed6's Avatar
Default Re: (redzcstandardhatch)
I'll try the accord cap. If you look the MSD cap IS just a stock cap that they put their kit on, and I can't justify $40 for it.
-Dustin
Junaid K
Mar 22, 2014 10:26 PM
honda_SiRII94
Apr 9, 2007 08:14 AM
newfie24
Apr 14, 2006 07:36 PM
SpoolnByYou
Mar 25, 2006 09:10 AM
