Transmission problems on a 97 civic ex
Old Aug 30, 2001 | 04:08 PM
MortalistiCivic's Avatar
New User
Default Transmission problems on a 97 civic ex
my 97 civic ex .... manual transmission makes noises ... It had about 57k miles on it and my transmission just started making noises when i downshift... from 3rd to 2nd and slow down... but when i start from 0mph.. and accelerate u hear normal.. but then again i downshift and i don't know what that noise is from its like when i pop the clutch it just grabs with a wierd noise...... so i thought it was the clutch.. i put a new clutch.. but the noise still continues.. any clues??? could it be the flywheel?.....thanx for the help
Old Aug 30, 2001 | 10:59 PM
5gen-hybrid's Avatar
New User
Default Re: Transmission problems on a 97 civic ex (MortalistiCivic)
could you describe the noise a little better then just a weird noise??????
Old Aug 31, 2001 | 11:07 AM
New User
Default Re: Transmission problems on a 97 civic ex (5gen-hybrid)
its like when i downshift.. it makes a noise that grabs and grinds real bad...
Old Aug 31, 2001 | 02:35 PM
CivicFerio's Avatar
your synchronizers might be shot... if they grind really bad you might have to drop and rebuild the tranny..
Charleston
Old Sep 2, 2001 | 11:02 PM
New User
Default Re: Transmission problems on a 97 civic ex (CivicFerio)
thanks alot man.. do u know how much this is goin to cost?
Old Sep 3, 2001 | 05:17 AM
eg6ajk's Avatar
first try changing your tranny fluid with MTL (if haven't done so)...need about 2liters....
as far as fixing it its cheaper sometimes to get a good used tranny then rebuilding..
Old Sep 3, 2001 | 10:04 PM
New User
Default Re: Transmission problems on a 97 civic ex (eg6ajk)
thanks alot.. i'm goin to put tranny fluid.. but where does that go in manual transmission?
herasi
Dec 16, 2011 03:35 PM
3rdhonda
Dec 5, 2011 08:04 AM
GIL7198
Transmission & Drivetrain
Jan 9, 2011 11:18 AM
ekblack9
23
Mar 14, 2007 10:26 AM
