will stock EK civic (96-00) fit EG civic (92-95)?
EDIT: forgot suspension in the title lol
After comparing the two, the springs appear to be almost identical, but the EK shocks appear to be slightly longer but its hard to tell if that will cause them not to work properly or not. My EG shocks are toast and the EK shocks are almost new so Id like to use them if possible. Any help is appreciated. Thanks
The front ones should fit but the brackets for the brake lines are different. The rears are like he said different where it mounts to the lower control arm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN »</TD></TR><TR><TD CLASS="quote">I know you just want to save some money!!! but why not upgrade now?
some time using stock part is like degrading!</TD></TR></TABLE>
Its my beater. and I had some ghetto *** coilovers on it so I could lower it. but now I wanna raise it up for the winter and the stock shocks are shot.
some time using stock part is like degrading!</TD></TR></TABLE>Its my beater. and I had some ghetto *** coilovers on it so I could lower it. but now I wanna raise it up for the winter and the stock shocks are shot.
EK rear lca's can fit the EG, but the geometry will be wrong. you can grid down the bushings on the EG lca's so u can use EK shocks on the EG. I kno b/c i have 00 si GC's and AGX's on my car (i got them for $300, couldnt wait for the proper eg shocks). btw, agx's for the rear on EK's are 8 way, while the EG/DC application is only 4way
Jonsta
Apr 29, 2014 09:21 AM
blarue09
May 18, 2010 03:50 PM
vizsual00
24
May 26, 2004 10:09 PM
