SOHC turbo onto GSR?
Old Oct 12, 2003 | 12:01 PM
GS-Rcivic's Avatar
Default SOHC turbo onto GSR?
I coulnt find anything on seach but was wondering if i were to get the sohc greddy kit, can i just change the manifold and use that whole kit on a 94 b18c1 in a 5th gen hatch? I only want to run at most 8 psi and i have 10.6:1 CR JE pistons in there. I want to use the vafc hack also. Any thoughts or advice? Thanks
Old Oct 12, 2003 | 06:19 PM
VTC_CiViC's Avatar
Default Re: SOHC turbo onto GSR? (GS-Rcivic)
Yes, you can.
Old Oct 12, 2003 | 06:23 PM
Ricey McRicerton's Avatar
Default Re: SOHC turbo onto GSR? (VTC_CiViC)
the turbo will spool really quck and you wont have a ton of top end power. (my thoughts)
Old Oct 12, 2003 | 09:37 PM
Johnyquest's Avatar
well, yeah, technically it would work, but if your throwing away the manifold AND fuel management kit from the greddy kit your really not using much from the kit but the turbo... so then why buy a kit in the first place?? The charge pipes most likely wont fit. I'd say go junkyard, get a t3-60trim off ebay or somewhere, and a t3 manifold (easy) and do it that way. Make the charge pipes yourself (jcwhitney) and afc-hack. You will be much happier, and it'll be cheaper that way, too.
Old Oct 13, 2003 | 04:48 AM
GS-Rcivic's Avatar
Default Re: SOHC turbo onto GSR? (Johnyquest)
woulnt the t3 be too big for my aplication, i am using 10.6:1 pistons.
Old Oct 13, 2003 | 10:27 AM
Johnyquest's Avatar
no, t3 super60 would be great for your app. Compression is a little high, better have a good tuning-ems.
Old Oct 13, 2003 | 06:39 PM
Charlie Moua's Avatar
the 15g on a stock gsr motor will reach full spool of 8psi at about 2500rpms!
it will die out after about 6,000rpms on a B18c1.... you will not be happy.
the 15G on a b16a would be ok but it would drop off top end just like the GSR but later at about 7k ish. good for cheap turbo kit.
The turbo from the APEXI d16 would be very STOCK like pick. full spool of 8spi at 2300-2400rpms and pulls strong and very gradually to redline. It will not make more topend power & PULL STRONG than say a t3t4, but the powerband will appear as if your car was ment to be boosted and very smooth . Great daily driver and street killer. Max psi on a stock b18c1 pulling to redline would be about 14psi, which should get you about 300whp give or take 15whp if your car is tuned.
trust me ..... hehe
s2000june
Jun 22, 2004 09:12 PM
d15b7racer
Oct 8, 2003 06:48 AM
Neukin
Jul 24, 2003 08:51 PM
whitemike1644
Jan 10, 2003 11:46 PM
imonkie
Nov 17, 2002 06:48 PM
