maxing out a sohc greddy kit?
i want to throw one on my d16a6. whats the max boost you can get out of the kit with out upgrading stuff?
Will i have to upgrade anything in the kit for 15psi?
i dont know too much about the greddy kits, i buy and break things and then i find out, so please help.
Re: maxing out a sohc greddy kit? (toyosupr)
The 15G Tops out around 13 to 14 psi, any more boost then that, the turbo can't do anything else + i don't think there is a bigger turbo u can bolt on that greddy manifold, the 15g is the bigest for those type of manifold, u should just get a T3 manifold with a T3 Turbo with your greddy kit and sell that one, if u need to upgrade.
Re: maxing out a sohc greddy kit? (Quad-Damge)
well i can deal with 13psi that would make a great daily driver... i was thinking it couldnt handle more then 8psi. so what do i have to do to the kit to get it to work with 13psi?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">The 15G Tops out around 13 to 14 psi, any more boost then that, the turbo can't do anything else + i don't think there is a bigger turbo u can bolt on that greddy manifold, the 15g is the bigest for those type of manifold, u should just get a T3 manifold with a T3 Turbo with your greddy kit and sell that one, if u need to upgrade.</TD></TR></TABLE>
The Garrett T28's fit onto the 15G mani if you're looking for a larger turbo.
28's Put out around 14 to 15 psi, they are balling bering Turbo, but they are not that much better then 15G's, It's not really a good upgrade, sure it's a bit better, but if your toping out your 15G and T28 isn't a huge step up
It's Like going from a ICE-Man Intake to a AEM Intake. Same **** but like not much better.
Alot of D Series Turbo Kits come with a ball bearing T28 Its very common to see. Thanks for let me know i thought u had to change out everything
i run an 18g on my greddy set up. 437 whp. where your kit will run out of head room is with the fuel. to safely boost 1 bar or so u will probubly need some 450's or larger. and and e-manage, or a hondata of such.
14-15 max on the 15g
the 18g from the integra kit will bolt right up to the sohc greddy manifold but the efficiency of the manifold comes into play...
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyosupr »</TD></TR><TR><TD CLASS="quote">well i can deal with 13psi that would make a great daily driver... i was thinking it couldnt handle more then 8psi. so what do i have to do to the kit to get it to work with 13psi?</TD></TR></TABLE>
get rid of the dinky sohc downpipe and go with a 2.5" DP and at least a 2.5" exhaust.
trooper0641
21
04-13-2004 11:08 PM
