What are the best turbo plugs to use
The 4554's are not really that great. You want a flat electrode and not the V-power (v-grooved center electrode).
I recommend the 3330's, BCPR7ES. The BCPR7ES-11's are the same plug but they come with a larger pre-set gap of about .044.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a »</TD></TR><TR><TD CLASS="quote">The 4554's are not really that great. You want a flat electrode and not the V-power (v-grooved center electrode).
I recommend the 3330's, BCPR7ES. The BCPR7ES-11's are the same plug but they come with a larger pre-set gap of about .044.</TD></TR></TABLE>
so why dont you want the v-grove? and what part of the part # means the vpower ones. i wll need to get some 6 heat range flat electrode ones.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a »</TD></TR><TR><TD CLASS="quote">I recommend the 3330's, BCPR7ES. The BCPR7ES-11's are the same plug but they come with a larger pre-set gap of about .044.</TD></TR></TABLE>
and theys cheap too...i ran the 3330's in all my turbo cars, from a 650whp supra to my dsm with a 60-1....my friend also runs these plugs in his turbo gsr at 400whp
i like the zex plugs.they have worked flawlessly for me and made 10 more whp than the denso iridium and 7 more than the ngk bcpr7es11.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR »</TD></TR><TR><TD CLASS="quote">i like the zex plugs.they have worked flawlessly for me and made 10 more whp than the denso iridium and 7 more than the ngk bcpr7es11. </TD></TR></TABLE>
Did you do a single dyno run after installing each different set of plugs?
I'm curious how you got those numbers...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic »</TD></TR><TR><TD CLASS="quote">bcpr7es-11
agree'd
</TD></TR></TABLE>agree'd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GudeH23a »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=510127
All you ever wanted to know about spark plugs...</TD></TR></TABLE>
Thanks for posting my link!! I feel proud!!
And by the way, NGK DOES recommend using V-power center electrode for turbo.....at least that is what they told me and I quoted in the article!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">ngk number 4554</TD></TR></TABLE>
Good plug if you are over 400hp which I am pretty sure you are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic2 »</TD></TR><TR><TD CLASS="quote">which exact plug you talking about for over 400hp by ngk that they recommend for turbo</TD></TR></TABLE>
Look just above your post.
http://www.sparkplugs.com/resu...&y=11
so that plug you think is the best someone eles said the v-power isnt the best but i just want something that will do it job and well thanks for the link too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic2 »</TD></TR><TR><TD CLASS="quote">so that plug you think is the best someone eles said the v-power isnt the best but i just want something that will do it job and well thanks for the link too</TD></TR></TABLE>
For 400hp, yes it is a great plug just like Jared uses. I am telling you directly what NGK says. I would say that is a great source.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron »</TD></TR><TR><TD CLASS="quote">
I'm curious how you got those numbers...</TD></TR></TABLE>
yes.
yes.
</TD></TR></TABLE>have my h22 turbo in my car with these plugs for 3 years with no probs not the same plug but you know what i mean
