vafc2 ???
Thats "limp mode" I believe. The ECU is protecting the car from revving too high until some problem is fixed. Most commonly happens when people let thier oil get too low.
Maybe theres a bad sensor connection somewhere?
I have checked all connections and the oil level. its all fine everything is perfect the car runs fine and hits vtec fine until the check engine light comes on then the car only revs to 4 grand help please
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLK KING »</TD></TR><TR><TD CLASS="quote">just installed vafc2 it works but car is cutting off @ 4000 rpms anyone have any idea why ???
thanks for the help </TD></TR></TABLE> You need to set your VAFC2 to your vehicle's specs. It's in the VAFC manual.
assuming you have the English manual, can you scan, photograph, anything, page 11 for me please??? The VAFC2 i bought is all in japanese, thanks ahead of time.
-Steve
-Steve
yeah, you have to connect the vtm wire...check on clubrsx for a ecu chart with the spot for the vtm wire
what do you have your vtec set at? i think as long as you keep it above 5200 rpm, even with the vtm wire disconnected, it will run fine and the check engine light will stay off...when you try to go lower than that is when you run into problems (after you hit vtec of course)
I love it, people post links and advice without knowing the site doesn't include VAFC2 instructions, BUT I'm sure this guy thinks I'm retarded for not looking. I have looked on their website and I have searched, but to no avail. There are different wires on the VAFC and VAFC2 so I can't use those.
Dont worry I dont think your retarded, I was just trying to help. Last time I was searching for a schematic I saw the U.S update posted on the Apex'i site and I just thought it would help you out. Sorry for the false lead or for underestimating of your depth of research.
no hard feelings, bro. i appreciate your help anyhow. i'm just getting pissed cuz i can't find out how to install and it's been sitting in my room for like 2 weeks now!!!
edit: http://www.prostreetonline.com...I.asp
get a plug and play wire hardness i know they make them. i just cant think of the name but if anyone else knows what i am talking about please let the OP know thanks lol
jdmchris626
12
Oct 4, 2007 08:01 AM
