SRP 9:1 pistons , dropped valve, reusable? pics
I wouldn't use them. Those dents could've disfigured the entire piston in some way, making it weaker and warped. They could ruin your block if you used them again...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd »</TD></TR><TR><TD CLASS="quote">I wouldn't use them. Those dents could've disfigured the entire piston in some way, making it weaker and warped. They could ruin your block if you used them again...</TD></TR></TABLE>
definitely true, those dents will probably be big hot spots on the pistons too increasing chances of detonation. dont use them again
I was thinking about getting a machine shot to lay a bead of tig weld and re surfaced flat. Think it would work.
I would be reusing the 3 and getting a new 4th.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EG »</TD></TR><TR><TD CLASS="quote">minor pitting ??
those look like grand canyon</TD></TR></TABLE>
i think you can order just 1 piston from JE/SRP.. they are all of the shelf pistons... try giving them a call, and make sure you give them the right info on your piston...compression/bore size
AgentJam
Apr 26, 2004 05:48 AM
crx1856
Nov 3, 2003 05:10 AM
