Injector is stuck on ?
Old Oct 11, 2003 | 02:55 PM
100whplusperliter's Avatar
Default Injector is stuck on ?
I blew a head gasket a week ago and just finished putting everything back together and am working out some problems.
I had the car starting and running ok for a little wile and, I was working on misc things.
And now when turn the key to the second on position the 4th injector stays on always. I must have lost a 1/4 tank in that cylinder It was coming out of the exhaust manifold when I pulled the plugs I must of shot a 3 footer out of the cylinder.
I stuck a noid light in the plug and it is on when the key is on, the others are off.
Does the ecu pulse/ground the injector ? Or send power ?
Should I check for a short to ground, between ecu and injector ? If so I need wiring schematics.
Anyone have any imput ? or anything i should check ?
I am starting to stressssss
Thanks,
Jack
Old Oct 11, 2003 | 02:57 PM
xmd's Avatar
xmd
yes, it pulse grounds the injectors. injectors are Aplug in the ECU
-x m d
Old Oct 11, 2003 | 08:18 PM
red civic standard's Avatar
Default Re: (xmd)
check for injector wires in your engine bay that could be possibly grounding out.
davethomson
Dec 9, 2018 04:23 AM
Chickenjoe757
Jan 9, 2018 03:30 AM
B_Swapped93
Apr 24, 2013 08:44 PM
TwoKSiR
Sep 23, 2010 06:09 PM
CHRIS29
Jun 9, 2009 04:43 PM
