Clutch Gone. Replacement/Warranty?
Old Oct 11, 2003 | 11:10 AM
:jdmshmaydm:'s Avatar
Default Clutch Gone. Replacement/Warranty?
Well I think my clutch is toast. I got into my car this morning and the thing just went in so easily when I pressed it to the ground. It goes down like nothing 2/3 of the way, then it gets some slight tension before it hits the floor. Before then it's real loose feeling and is light like a feather. Put your foot on it and without no pressure it'll go down 2/3.
I can't get it into gear now when the car's on, and last night when I was coming home I noticed it was kinda tough to get it into each gear when I shifted. I was considering going aftermarket but don't know what would suit me best. I guess I wouldn't mind something that performs a little better and delivers more power than stock.
I was wondering if Acura would replace it under warranty? The car's a 2000 GS-R that was bought from the dealer in Dec. 00. The clutch shouldn't go out after only three years, but I race my car every now and then. You think that would hinder my chances of getting them to replace it under warranty? They might get the idea I race it because of the lack of backseat, the exhaust, and it's lowered. Obviously I wouldn't bring it up.
Old Oct 11, 2003 | 11:44 AM
threatcon13's Avatar
New User
Default Re: Clutch Gone. Replacement/Warranty? (Gatecrasher19AF)
Is the car still under warranty? Being lowered, having no back seat, and having exhaust doesnt mean that your car won't be covered under warranty....and in noway whatsoever deems your car as a racecar.
Old Oct 11, 2003 | 12:49 PM
Default Re: Clutch Gone. Replacement/Warranty? (Threatcon13)
Well to some people it may seem so. Yes my car is still under warranty too.
Old Oct 11, 2003 | 02:02 PM
LSTEG96's Avatar
sounds like master cylinder/slave cylinder problem...
Old Oct 11, 2003 | 02:14 PM
oMek's Avatar
Default Re: Clutch Gone. Replacement/Warranty? (LSTEG96)
i thought clutch was not under warenties, because its a wear and tear part like brake pads
Old Oct 11, 2003 | 06:06 PM
mindsidecollective's Avatar
I had a similar thing happen on my 96 GSR, out of the blue....My fiance's father took a look at it, and bled the clutch and brake resiviors....once the air was out, the clutch started working fine....try that.....:0)
Old Oct 12, 2003 | 12:45 PM
Default Re: Clutch Gone. Replacement/Warranty? (mindsidecollective)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mindsidecollective &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar thing happen on my 96 GSR, out of the blue....My fiance's father took a look at it, and bled the clutch and brake resiviors....once the air was out, the clutch started working fine....try that.....:0)</TD></TR></TABLE>
Sounds good. Yeah it was out of the blue this happening. The night before it worked fine. I didn't sense any wear of the clutch before hand. It was just the next day that it was all flimsy like and I couldn't get it into gear.
Old Oct 12, 2003 | 01:38 PM
wall of tvs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like master cylinder/slave cylinder problem...</TD></TR></TABLE>
Yup -- and it's EASY to fix. Parts shouldn't cost more than 250-300 bucks for the master and slave cylinders.
Old Oct 12, 2003 | 02:38 PM
thaiphob's Avatar
Nikon!!!
Default Re: Clutch Gone. Replacement/Warranty? (wall of tvs)
clutch is a ware n tare item.not covered under warrenty.
buymesomedunks
Jul 13, 2013 10:30 PM
civicexkid1
18
Jun 28, 2012 10:52 AM
JerseyGuy35
Honda Civic (2006 - 2015)
Jun 16, 2007 04:01 PM
GO-FIGHT-KILL
Oct 23, 2006 01:48 AM
General Kills
Sep 17, 2004 11:54 PM
