what "ecu" should i run for my setup? anh what kinda hp would i expect?
i'm looking for one of the best ecu's for my built b20/vtec:
setup-
head
-built by PYR
-complete skunk2 valve train, stage 2 cams & cam gears and with sk2 manifold
-68mm str throttle
-310 RC injectors
-aem fuel rail and FPR
-venmon fuel pump
b20 block
-golden eagle resleeve
-wiseco 12:1 pistons
-crower rods
-8lbs. fly wheel, unorthodox single pulley
-itr oil pump
-itr block girdle
-act pressure plate and 6 puck
MSD digtal 6, cap and coil
setup-
head
-built by PYR
-68mm str throttle
-310 RC injectors
-venmon fuel pump
b20 block
-crower rods
-itr oil pump
-itr block girdle
but if cost is an issue a skunk2 chip in a P28 would be fine with the aid of the vafc. I like skunks program better than any of the other chipped ecus out there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett »</TD></TR><TR><TD CLASS="quote">but if cost is an issue a skunk2 chip in a P28 would be fine with the aid of the vafc. I like skunks program better than any of the other chipped ecus out there. </TD></TR></TABLE>
Then you haven't ran Kenji's.
You can buy a brand new Hondata for cheaper then a brand new chipped P28 and AFC.
You can also buy a used Hondata for cheaper then....
Keni's is essentially a skunk2 replica, but more rich and a higher duty cycle on the injectors, both uncessary things if you have the proper sized injectors. I suppose for stock type r engines it may be good for maybe 3-5 hp in the midrange over a skunk2 but that is it. I would love to see a dyno plot of a skunk2 chipped p28 vs a kenji p28. His chip is good but I don't beleive any better than the skunk2. Plus if I rememebr correctly kenji's chip has/had some problems wtih fluctuating idle. and hondata in it's barest form without the chippedd ecu can be purchased for cheaper than chipped ecu and vafc, but you still need a chipped ecu for hondata so cost is cheaper the vafc route
asc
Jul 17, 2008 05:44 PM
92slowvic
Aug 20, 2004 05:41 AM
SIReg9
Apr 30, 2003 08:02 AM
fukaintmuven
Nov 7, 2002 12:02 AM
