d16z6 performing like crap.
Old Oct 10, 2003 | 08:59 PM
bluuuurr's Avatar
Default d16z6 performing like crap.
It started about 2 weeks ago. The entire performance of the engine seems to have mysteriously decreased. I changed the plugs with no effect. It feels like when I push on the gas the revs don't go up nearly as fast or smoothly as they used to. And there is a slight hesitation between when I push the gas and the rpm rise. Plus it bogs like a bitch when I try to get it in 1st and 2nd gear. Please help, I'm not sure how to describe it better, sorry guys.
Old Oct 10, 2003 | 09:08 PM
HATCHingMN's Avatar
Default Re: d16z6 performing like crap. (bluuuurr)
You say rpm rise, do you mean rpm rise but no acceleration....if you're still on the stock clutch, a new clutch is calling on you. Because rpm rise and no acceleration means your clutch is slipping!!
Old Oct 10, 2003 | 09:13 PM
bluuuurr's Avatar
Default Re: d16z6 performing like crap. (HATCHingMN)
no no, the clutch is fine, it's definitely the engine. it's sota like the same effect as driving with the a/c on. but the a/c s definitely off.
Old Oct 10, 2003 | 09:31 PM
civic_tuned's Avatar
welcome to world of hondas . Im thinking it has something do with your fuel system it could mean a lot things.
1. fuel filter might be clogged up
2. fuel injectors are dirty
3. gas regulator
4. sensor
solution: your best bet is to get a computer check and a mechanic can tell u what wrong.
FS
apexi vafc~new
92-95 civic tanabe springs
92-95 civic ex venom 400
d16 jdm header (bigger ports)
Old Oct 10, 2003 | 09:56 PM
Mista Bone's Avatar
D Tranny Guru
either the dist. moved, timing belt skipped a tooth, or the rotor inside the dist. is loose and has shifted.
Old Oct 11, 2003 | 08:43 AM
blackeg's Avatar
Default Re: d16z6 performing like crap. (Mista Bone)
this happens to my z6 too. every now and again it feels like its lost a little power and doesnt rev a quickly/smoothly. then it kinda goes away outta nowhere. id like to know what the deal with it is too
Old Oct 11, 2003 | 08:46 AM
infinatenexus's Avatar
change your cap and rotor
change your air filter
change your fuel filter
Old Oct 11, 2003 | 11:18 AM
handa's Avatar
I've also had similar problems with my D16Z6.
My car runs smooth and takes off really fast on the startup. But after a about 5 mins after it has been running, it seems to run weaker and weaker and does not take off as fast.
Old Oct 11, 2003 | 12:01 PM
DevLishPlaya's Avatar
up can anybody shine some light on this, i too would like to know
Old Oct 11, 2003 | 12:06 PM
tominos's Avatar
Default Re: (DevLishPlaya)
try a basic tune up first. cap rotor wires etc.
Old Oct 11, 2003 | 03:46 PM
blackeg's Avatar
Default Re: (infinatenexus)
i changed my cap, rotor, plugs and air filter and it still sometimes happens. i have a new fuel filter that im gonna put on in like a week, and if it stops the problem i'll let everyone know.
Old Oct 12, 2003 | 01:17 AM
D16Z6racing's Avatar
Default Re: (blackeg)
How many miles are on this engine?
Old Oct 12, 2003 | 01:35 AM
BatuKing's Avatar
Default Re: (D16Z6racing)
How about adjusting your valves?
Old Oct 12, 2003 | 03:19 AM
GTlvr82's Avatar
Default Re: (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">How about adjusting your valves? </TD></TR></TABLE>
Actually, that worked for my old D15B7 like you wouldn't believe. I just got the valves adjusted on my D16Z6 and it improved get-up and a few horses on the butt dyno.
Old Oct 12, 2003 | 09:10 AM
blackeg's Avatar
i have 133,xxx on my car and engine right now. i know for a fact that the valves have not been adjusted within the last 60k miles and maybe more. im gonna put a new head on in a few weeks, so hopefully it wont act stupid on me then.
Old Oct 12, 2003 | 09:37 AM
slowd16z6's Avatar
I had a sim problem, swore it wasnt my clutch... then 3 days later not accelerating on the hwy I figured it out.... You owe me exedy!
ac_attak
Sep 5, 2008 09:53 AM
mugencivic94
11
Feb 15, 2006 09:05 PM
eMpAtHy
Oct 14, 2004 11:31 PM
shipsaeki
Sep 24, 2002 10:45 AM
LOwrestling2001
May 26, 2002 03:28 AM
