will i pass emissions with my setup?
Old Oct 10, 2003 | 11:29 AM
T3T495GSR's Avatar
Default will i pass emissions with my setup?
i have a drag 3 kit and am running vafc hack with 440cc injectors . if i go to the place with an IC pipe disconnected so the engine doesnt see boost and i have a cat will i pass? or do i need to change my injectors to stock? thanks
Old Oct 10, 2003 | 11:52 AM
P1mpSlap's Avatar
only one way to find out.
I bearly passed with my CTR pistons. I was about 6 points away from something to failing.
I let the car warm up for about 30 minutes before I took it there tho.
Old Oct 10, 2003 | 02:50 PM
Xumarius's Avatar
Default Re: will i pass emissions with my setup? (T3T495GSR)
it's called denatured alcohol. my friend!
Old Oct 10, 2003 | 09:09 PM
T3T495GSR's Avatar
Default Re: will i pass emissions with my setup? (Xumarius)
my question is if the injectors will make me fail since they are 440cc but i still wont be boosting anyways so does it make a difference?
Old Oct 11, 2003 | 06:37 AM
djay86's Avatar
not sure about the injectors.. but if you run a VAFC or SAFC cant you lean the **** out of it, and basically pass anything?
Old Oct 11, 2003 | 06:41 AM
cyrk007's Avatar
Default Re: will i pass emissions with my setup? (djay86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djay86 &raquo;</TD></TR><TR><TD CLASS="quote">.. but if you run a VAFC or SAFC cant you lean the **** out of it, and basically pass anything?</TD></TR></TABLE>
this is acurate.. if your system is tuned correctly and you down have blow-by it should pass.. if your cat is in working order you should have no problem..
Old Oct 11, 2003 | 06:59 AM
T3T495GSR's Avatar
Default Re: will i pass emissions with my setup? (cyrk007)
what about the injectors though? my hydrocarbons were 3.88 and they should be .80 isnt that unburned fuel thus meaning its the injectors that need to be changed?
ramennoodles
Jan 6, 2005 05:23 PM
1.8T_EG
Dec 9, 2003 09:11 PM
SlamMan
Jun 8, 2003 03:51 PM
aemciv
Feb 26, 2003 11:31 AM
1.8T_EG
Sep 16, 2002 12:22 PM
