shifting Shaking bad when at 7900 Rpm
Old Oct 10, 2003 | 11:27 AM
wireballz's Avatar
Default shifting Shaking bad when at 7900 Rpm
need to know what would cause this problem of my shifter rattles about 7900-8000
at any gear any ideas
thanks
Old Oct 10, 2003 | 12:21 PM
RedLinin247
Guest
Posts: n/a
Default Re: shifting Shaking bad when at 7900 Rpm (wireballz)
lol are you cruising around at that rpm? probably something to do with your shifter rubbing maybe? idk.
Old Oct 10, 2003 | 02:40 PM
wireballz's Avatar
Default Re: shifting Shaking bad when at 7900 Rpm (RedLinin247)
i don't think it is the rubber because it is tight , i hope i can find out what it is
Old Oct 10, 2003 | 03:02 PM
scrap1ngsr's Avatar
If I were you i wouldnt worry too much about it, you dont spend that much time at that rpms and if you do then you are constantly bouncing off the rev limter
Old Oct 10, 2003 | 04:43 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Uhh you can't do anything about it, sorry. What do you expect from an engine turning 133 revolutions per SECOND, silky smoothness?
The plastic ring on top of my shift boot rattles alot when I get close to redline, but that's only because it's loose. Just live with it.
VTECth1s
Transmission & Drivetrain
Feb 8, 2009 09:04 PM
91blackEF
Jan 9, 2009 05:39 AM
RsxType-Stitch
Jul 14, 2005 10:38 PM
GroovyNeilNeil
Jul 2, 2004 11:48 AM
Death_to_Thieves
Nov 1, 2002 09:39 PM
