Spark Plug wires keep popping out
Old Oct 10, 2003 | 06:57 AM
ramz7887's Avatar
Default Spark Plug wires keep popping out
I have a set of accel spark plug wires. When i drive around for a while and then look under my hood the 1st one and the 4th one are looses. I push them back in and then drive around and the same thing happenes. I don't know if i'm loosing any power though. The cars still runs good. what should i doo to make sure they stay in?
Old Oct 10, 2003 | 07:01 AM
spencedogg's Avatar
widen or tighten the clip with some needle nose plyers i had to dothat to mine
Old Oct 10, 2003 | 07:14 AM
Andres-eh2's Avatar
are they the right ones for your car? not all civic ones fit alike.
Old Oct 10, 2003 | 07:15 AM
CXHatchback's Avatar
Default Re: (EGEESIX)
And I might as well add before others do...... OEM plug wires are your best bet.
Old Oct 10, 2003 | 08:04 AM
allmotorEG-SI's Avatar
Default Re: (CXHatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHatchback &raquo;</TD></TR><TR><TD CLASS="quote">And I might as well add before others do...... OEM plug wires are your best bet.</TD></TR></TABLE>
not too long ago someone posted a link to the website of the fastest allmotor honda and everything is modified except the iginiton. Thats all stock.
Old Oct 10, 2003 | 08:23 AM
Spade's Avatar
Default Re: (allmotorEG-SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorEG-SI &raquo;</TD></TR><TR><TD CLASS="quote">
not too long ago someone posted a link to the website of the fastest allmotor honda and everything is modified except the iginiton. Thats all stock.</TD></TR></TABLE>
Yup. Erick's racing.
Old Oct 10, 2003 | 08:26 AM
Navid OG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGEESIX &raquo;</TD></TR><TR><TD CLASS="quote">are they the right ones for your car? not all civic ones fit alike.</TD></TR></TABLE>
that would also be my guess too..... make sure they are the right ones
Old Oct 10, 2003 | 08:36 AM
sir2k's Avatar
Default Re: (Navid OG)
mine did that for a while with the stock spark plug wires, good thing the spark plug wire cover held it in.
what happened to mine was that the spark plugs were broken. The core and the thread part (shell) was loose and you can move it up and down and turn it around (really bad condition).
so check the spark plugs if you think you got the right wires in the first place.
Old Oct 10, 2003 | 11:44 AM
ramz7887's Avatar
Default Re: (sir2k)
I know that i have the right wires and plugs for my car. Do you think if i put some more of that silicone stuff on the wires it will help hold it in?
Old Oct 10, 2003 | 11:50 AM
Spade's Avatar
Default Re: (ramz7887)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 &raquo;</TD></TR><TR><TD CLASS="quote">I know that i have the right wires and plugs for my car. Do you think if i put some more of that silicone stuff on the wires it will help hold it in?</TD></TR></TABLE>
I had this problem....switched to Bosch wires....Autozone had them and that is what I have been using ever since.....the Accels suck *** IMO.
Old Oct 10, 2003 | 12:42 PM
duRritztiNy's Avatar
Default Re: (Spade)
use ducktap
Old Oct 10, 2003 | 12:47 PM
TrickHonda98's Avatar
Default Re: (SouthSideRacing)
squeeze the connector around the s. plug.
Old Oct 10, 2003 | 01:54 PM
HATCHingMN's Avatar
Default Re: Spark Plug wires keep popping out (ramz7887)
If you want a permanent fixed = use super glue!!
or...
If that not what you have in mind go to the nearest Honda dealer and get yourself some new NGK sparkplug wires!!
Old Oct 10, 2003 | 03:04 PM
slowd16z6's Avatar
They got a good deal on ngk wires and plugs at http://www.groupbuycenter.com right now.
Old Oct 10, 2003 | 03:12 PM
Mike P.'s Avatar
25 Year Member
Not that this is something that you probably want to hear, but I had a bad experience with Accel wires a few years back and have stuck to OEM Honda wires ever since then. Can't go wrong.
Old Oct 10, 2003 | 03:16 PM
hybrid93SIvic's Avatar
Default Re: Spark Plug wires keep popping out (Mike P.)
OEM is fun...nothing is more reliable them OEM
Old Oct 10, 2003 | 05:25 PM
rolow's Avatar
Default Re: Spark Plug wires keep popping out (hybrid93SIvic)
If it is happening on the distributer cap I would use zip ties
Old Oct 10, 2003 | 07:20 PM
NonovUrbizniz's Avatar
Loved
Default Re: Spark Plug wires keep popping out (HATCHingMN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">If you want a permanent fixed = use super glue!!
or...
If that not what you have in mind go to the nearest Honda dealer and get yourself some new NGK sparkplug wires!! </TD></TR></TABLE>
If the dealer give you ngk wire's they don't sell "stock" parts... the stock one's are denso I think... NOT NGK though I KNOW that...
Anyway... to the poster...
You may want to be sure that the plugs are torqued down properly... if they're loose it can make the plugs pop off...
Also like mentioned... you can try sticking something up there to get the connections tighter... but also as mentioned some aftermarket wires just aren't as good as stock much less better...
The funniest thing I ever read about this was there was a site that did a spark plug "shootout" and the 8year old stock wires out performed both a set of ngk's and some other brand too... both reputable brands...
Go Figure.
dkrex001
Oct 4, 2006 03:18 PM
RACEPAK
Oct 25, 2004 07:04 AM
nickgmiller04
Mar 13, 2004 12:11 PM
B00ST2nR
Dec 14, 2003 02:03 PM
Dels98R
Jun 13, 2003 11:21 PM
