Spark Plug Wires
Old Dec 13, 2003 | 11:39 PM
B00ST2nR's Avatar
Default Spark Plug Wires
So does it make a difference by swapping out your stock Spark Plug Wires to bigger/better aftermarket Spark Plug Wires?
Old Dec 13, 2003 | 11:47 PM
xteg95's Avatar
Default Re: Spark Plug Wires (Skunk2nR)
depends on the application...i think it will really on help on more built engines, like FI and whatnot.
Old Dec 14, 2003 | 10:52 AM
mr.beeks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk2nR &raquo;</TD></TR><TR><TD CLASS="quote">So does it make a difference by swapping out your stock Spark Plug Wires to bigger/better aftermarket Spark Plug Wires?</TD></TR></TABLE>
bigger doesnt mean better basically the same function
the only thing that it will help you is with your AM reception
unless you are FI (darkside)
but better off with stock or NGK..
Old Dec 14, 2003 | 11:46 AM
StyleTEG's Avatar
Default Re: Spark Plug Wires (mr.beeks)
There are ten second all motor hondas using stock ignition system right down to the stock wires.
Don't both unless yours are worn and arcing.
Rory Breaker's Avatar
OEM wires are perfectly OK for most setups, NA and FI.
Old Dec 14, 2003 | 01:11 PM
maxxdout's Avatar
no
Old Dec 14, 2003 | 01:44 PM
B00ST2nR's Avatar
Default Re: Spark Plug Wires (maxxdout)
alright cool. Thanks for clearin that up.
Old Dec 14, 2003 | 01:48 PM
Rob Dizzle's Avatar
oem is good stuff
Old Dec 14, 2003 | 02:03 PM
NA gs-R 05 C
Guest
Posts: n/a
not really a need for aftermarket wires, stick with the stock ones, they're perfectly fine.
piggydog
Nov 12, 2005 05:05 PM
RACEPAK
Oct 25, 2004 07:04 AM
megotvtec
Oct 5, 2004 01:50 PM
osuperjohno
Jun 2, 2004 03:25 AM
KF_S2000
Feb 2, 2002 06:08 PM
