98+ GSR Rims Question =)
hey guys, just had a quick question on the 98+ blade gsr rims. Ive seen some people with some really, i mean really shiny gsr rims. almost look like there chrome, do you guys recommend anything to clean and or polish these rims to give them that super shine look? thanks in advance.
andre
andre
I just use soap and water. That usually does the trick.
I'm a little skeptical as to whether those wheel cleaners that are "clear coat safe", actually are.
This might be moved soon.
I'm a little skeptical as to whether those wheel cleaners that are "clear coat safe", actually are.This might be moved soon.
hey dre dre man wsup its me again......what i used for the most part was soap and water and a good scrubbing, but i also used a mag polish from mothers wax, ill show you when u get back to see what it was i used.....lol laterz island boy!
like everyone said. car soap and water does the trick.
The personal trick I learned from friends who worked at body shops was spraying down the rims and cleaning them with a good glass cleaner like windex. It helps to give it the shine we all look for and keeps off the brake dust
I used to do the wash/polish/wax with mine but have discovered a metal polish called maas. you should be able to find it in your Local Grocery Store in the floor treatment asile. It works wonders on polishing any kind of metal.
dont use wheel cleaner, it dammages the clear coat no matter if it says it dosent or not. If anyhting it creates micro abrasions in the coat that mke the rim looks not as shiny. I would use only soap and water, and it it gets REAL bad maybe use a very mild cleaner, like very sparingly on just the real tough spots. Meguirs and Mothers make a good product if you HAVE to use it.
guys you are not "polishing" metal. Your rims are clear coated. So with polish all you are doing is wearing down your clear coat and dammaging it. SO be careful with polishes.
