KS code 23 = no vtec = limp mode = driving me KA-RAZY!!!!!!!!!!
Old Oct 10, 2003 | 01:26 AM
drLazy's Avatar
Default KS code 23 = no vtec = limp mode = driving me KA-RAZY!!!!!!!!!!
set up:
obd1 ls/vtec
greddy 18G @ 9lbs
vafc + 95 gsr ecu
heres the deal, while cruising 4 or 5 gear at around 3k rpm, the check engine light comes on. cel 23 knock sensor right?? ive searched and tried everything the archives said: ground the wire, wire one in and leave it dangling, weld it to a alt bracket bolt,screwed it to the back of the head, ground it while hooked up to the harness blah blah blah......all bullshit!!!!
nothing has worked yet. theyre all honda urban legends. right now i have a custom bracket that alamo made for me. its a 2in thick peice of aluminum rectangle that has a threaded hole for the ks and another holw for a bolt to mount the bracket to the ac bracket on the front of the block.
still code 23, the only thing we havent tried is using a sheilded wire to the ecu. its using a std car wire wired directly to d3. i heard u need a sheilded wire for the ks? is this true, if so where can i find one: fry's, car toys, best buy, radio shack, home depot, lowes: nobody in town has it. i tried them all. and i cant really chip the ecu because its on loan from my buddy.
any other bright ideas peoples??? how do u get a ks to work w/ a obd1 p72 and ls block!!!!! if its the wrong section please move me. also the cel doesnot come on when im beating on it only when cruising, it came on only once on the dyno??? weird...ur telling me
Old Oct 10, 2003 | 01:42 AM
integra_gsr98's Avatar
Default Re: KS code 23 = no vtec = limp mode = driving me KA-RAZY!!!!!!!!!! (drLazy)
Try this... neat little trick from the DSM world...
Take the knock sensor and wrap it in 3 or 4 paper towels. Hold the towels on with zipties, and then ziptie the knock sensor up somewhere where it will be away from a LOT of vibration and will not get beat around.
Give that a shot and see how that works out. We've done it on a few DSMs that are getting a ton of phantom knock from noisy lifters.
Old Oct 10, 2003 | 06:26 AM
drLazy's Avatar
Default Re: KS code 23 = no vtec = limp mode = driving me KA-RAZY!!!!!!!!!! (integra_gsr98)
i'll try that tonight, thanks
Old Oct 10, 2003 | 09:26 AM
DIY_Racing's Avatar
ahaha, its not an urban legend man... It works.. You knock sensor is probably ****.. They break SOOOOOO easy.. And leaving it unplugged will not work.. it needs to sense SOMETHING or it will code.. Get a good ks and screw it back in...
Urban legends.... BLAH.. i wrote that article....
Old Oct 10, 2003 | 01:31 PM
drLazy's Avatar
Default Re: KS code 23 = no vtec = limp mode = driving me KA-RAZY!!!!!!!!!! (DIY_Racing)
ok maybe not urban legend but just those damn horsepower gremlins again
we already put the ks in my friends gsr and it doesnt code. also how it is now, is exaclty how u descibed it. its plugged in....its sensing the front of the block... and its a good ks....
if anyone is in the dfw/dallas area and think they can ground my problems away then i'll buy u lunch if u fix my problem
any challengers.....
Old Oct 10, 2003 | 02:26 PM
drLazy's Avatar
anyone else.....
Jdmkids Manny
Apr 26, 2016 11:06 PM
sleepyaccord96
Oct 16, 2013 08:23 AM
g4hatchie
11
Nov 27, 2004 11:55 PM
pelotudo
Jan 30, 2002 03:02 PM
Akira-R
Jun 22, 2001 12:37 PM
