header bolts part #
i need new header bolts like 3 of mine are broke. i read on here that i could use slave cilinder bolts.
i need the part # from
http://www.acuraautomotiveparts.org
thanks for the help
thanks for the help
I have one header bolt sitting right here as a matter of fact.
Honda part # 90026-PE0-000
This is the 2 part threaded bolt that bolts into the block, and the other part is for the header nut. Not 100% sure from the drawing on the link above, but it is the bolt where item #14 is indicating (99729). If that's it it's very cheap. Hope it helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap »</TD></TR><TR><TD CLASS="quote">honda #90001-P30-003 off a 00si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekone GBPDC2 »</TD></TR><TR><TD CLASS="quote">so part # #90001-P30-003 is for 1 stud and 1 bolt. and i need like 10 right?</TD></TR></TABLE>
no its the part number for the one header bolt. if you want the nut and stud those have different part #s. and you only need 9 bolts or studs and nuts.
That's the part number for the exhaust manifold bolts. You'll only need 7 of them. The two on the ends are normally studs/nuts.
I recommend using the two studs on the ends and using the bolts on the 7 in the middle. It makes it a lot easier to mount the exhaust manifold/header if you have just the two on the ends as studs.
you got it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekone GBPDC2 »</TD></TR><TR><TD CLASS="quote">so i need to order 7 of that part #?</TD></TR></TABLE>
Prudz_lude
Mar 29, 2007 01:18 PM
