84mm piston???
Old Oct 9, 2003 | 05:47 PM
jaydmcrx's Avatar
Default 84mm piston???
For 84mm pistons for my b16a1, would I get custom ones, or use stock bigger size such as for a b20 or something with that bigger bore size? Anyone know of any good places to get pistons and rods for cheap? Thanks
Old Oct 9, 2003 | 05:50 PM
jaydmcrx's Avatar
Default Re: 84mm piston??? (jaydmcrx)
never mind i found endyn, they have all the stuff i need.
Old Oct 9, 2003 | 06:22 PM
RS_H22's Avatar
Hmmm... where could you go to get pistons and rods? hmmmm... lol
Your going to have to sleeve the block to go that big but I would recomend something light weight, say JE, CP or IB Spec Wiseco's... all of the above are very light weight, very strong and all alot lighter than ENDYN's wiseco line... Eagle rods are a tad on the heavy side as well, go with a set of Probe Ultra lite I beams, the lightest rod on the market for right now... Keep in mind I did say for right now
Modified by RS_H22 at 3:59 AM 10/10/2003
Modified by RS_H22 at 4:02 AM 10/10/2003
Old Oct 9, 2003 | 06:36 PM
jaydmcrx's Avatar
Yah i am going to get the block sleeved with darton sleeves, and use 12:1 pistons je or arias,with some eagle rods. yah and ill be checking our your website imediately haha
Old Oct 9, 2003 | 08:34 PM
ArinX's Avatar
Default Re: (jaydmcrx)
Ib Spec Wiseco's
Old Oct 10, 2003 | 07:35 AM
jaydmcrx's Avatar
Default Re: (ArinX)
Those are nice, look way less wild than those damn super dupers. What compression and bore size are those?
Old Oct 10, 2003 | 10:14 AM
JunIntegra's Avatar
what are the differenes between normal and ib spec wiseco's?
Old Oct 10, 2003 | 10:15 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: 84mm piston??? (RS_H22)
Why does everything think Eagle rods are so heavy? Is it just because of the H-Beam design? Looks can be decieving. Pauter rods are actually quite light as well believe it or not.
Cunningham takes the cake on lightness though bascially because they can do just about whatever you want.
Any company should be able to make you 84mm pistons in just about any compression you want. Arias does custom for barely over OTS price. CP's are worth looking into. Top notch quality and probably one of the best for expanding properties, ring seating etc...
Old Oct 10, 2003 | 12:28 PM
jaydmcrx's Avatar
Yah I have heard good things about all of those companys, and also I have heard nothing but good things about eagle rods, But I have been looking into cunningham also and I think I am going to go with...I have narrowed it down too Wisceo or arias pistons 12:1 84mm , and eagle or cunningham rods. What would I have to do to make the wisceo super dupers work in my car......Those are also looking quite tempting.
Old Oct 10, 2003 | 02:29 PM
ArinX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx &raquo;</TD></TR><TR><TD CLASS="quote">Those are nice, look way less wild than those damn super dupers. What compression and bore size are those?</TD></TR></TABLE>
11.8 compression 84.5mm
the compression varies a little on what head/crank you are using.
Old Oct 12, 2003 | 11:13 AM
97lsvtec's Avatar
Default Re: (ArinX)
brad from rlz can get you some awesome pistons, to his specs
93delsolJDM
Feb 13, 2011 11:25 PM
tspkenneth
Jan 7, 2005 03:46 PM
turboex
Oct 15, 2002 03:00 PM
93B17A
Feb 4, 2002 03:08 PM
downpipe
Dec 14, 2001 12:02 PM
