I need some help about camber kits!
Where to find a good price on a good quality camber kit for my 90 hatch. Since I put my suspension on(what contains in my sig below), i have been getting some mad camber.
Thanks for the help
Thanks for the help
Specialtie Products companie,...I believe make a set that the local wheel and tire shop sells. It is adjustable from 1.75 degree to 3.25 degree.
I bought that one for my CRX, but when I changed from ( cheap ) coil overs to lowering springs, they were seriouse overkill.
They probably would have been great on the coiled over suspension. I think they were around $80 a kit( 2 kits neede, one per side ). Oh yeah, these are front only, I don't know about the rear.
Screw those cheap ones like the Ingalls kit. Get one that replaces the entire upper A-arm. They cost more but they're much better. You get better adjustability and they don't slip. The Skunk2 kit only costs $225. Or you can go for the bling bling King motorsports kit which is a steal at $400.
i'm running the progress camber kit, it doesn't compensate for a whole lot, but it leaves a little bit of camber with my 2.5" drop springs, and i like it like that. the sprint kit i spoke of was tough to get in because the new anchor bolts were wide, very wide. i had to put the control arm in a vice and spread the mounting area wider, it was a wierd fit and didn't look quite right but when everything was tightened down it was no big deal.
i like the idea of the whole a arm like the skunk 2 kit. i'd rather use new a arms with adjustable ball joints just because it's the whole unit. contact skunk2, you should be able to use a different application. i hate it when companies don't list/make apps for EF's. such a pain in the ***.
Ingalls Camber kits:
Groupbuycenter.com
Front:
3570/3571 88-95 Civic (REAR)(-5/8 to +1)-$119
3572/3573 88-95 Civic (REAR)(+1.25/+3)-$130
Rear:
3890/3892 88-00 Civic (-2/+3)-$110
Groupbuycenter.com
Front:
Rear:
hey what about those rain rear controll arm things that will lower your car up to 4" or so...... what's there web site? anyone know what i'm talking about? i have coil overs and kyb gr2's and i want some camber correction and some bounce controll.
