Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Two inch Harness at track events
Old Oct 9, 2003 | 11:29 AM
Reza.dc's Avatar
Default Two inch Harness at track events
Can you use a sparco 2 inch 4 point camlock at streets of willow or any other type of scca function. Thanks
Old Oct 9, 2003 | 03:23 PM
.RJ's Avatar
.RJ
Default Re: Two inch Harness at track events (reza)
could you? probably. Should you? no.
use stock belts or SFI approved 3" 5/6 points.
Old Oct 9, 2003 | 06:08 PM
Reza.dc's Avatar
Default Re: Two inch Harness at track events (.RJ)
thanks rj
Old Oct 9, 2003 | 10:37 PM
travis's Avatar
Ignoring safety for a moment, 2" belts are also very uncomfortable. I had 2" belts for two autocross days before I ditched them for the 3" belts. This was long before I needed a harness for safety.
Old Oct 10, 2003 | 01:13 AM
Reza.dc's Avatar
Default Re: Two inch Harness at track events (travis)
yeah wellmy car will be in events with more strict regulations then the scca. Hopefully..
so im going with the 3 inch sparco 5 point.
Old Oct 10, 2003 | 01:34 AM
jc836's Avatar
Care to tell us what sanctioning body is stricter? The FIA standard is 3" belts and harness with the anti-subs being 2".
Old Oct 10, 2003 | 01:49 AM
travis's Avatar
Default Re: Two inch Harness at track events (jc836)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc836 &raquo;</TD></TR><TR><TD CLASS="quote">Care to tell us what sanctioning body is stricter?</TD></TR></TABLE>
Old Oct 10, 2003 | 03:37 PM
Outsane's Avatar
And you thought the 2" was uncomfortable...
Old Oct 10, 2003 | 04:50 PM
BluGTIVR's Avatar
Just curious, why should you not use 2" belts?? I understand that 3" are the better and the safer belt to use but isn't a 2" with sub going to be a lot safer than just using a stock belt. (putting flame suit on)
Old Oct 10, 2003 | 08:46 PM
Reza.dc's Avatar
Default Re: Two inch Harness at track events (BluGTIVR)
i would imagine so, i think it has to do more with how strong the belt ( width ) is when it comes to the momentum straining the belt fibers during the impact or rollover.
Old Oct 10, 2003 | 11:53 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BluGTIVR &raquo;</TD></TR><TR><TD CLASS="quote">Just curious, why should you not use 2" belts?? </TD></TR></TABLE>
Alright, I said "ignoring safety," but you asked. 2" belts will stretch more than 3" belts under the same amount of force. Belts are supposed to stretch a little, but this is assuming you are using the FIA safety regs. are designed around the stretch of a 3" belt. Also, 2" belts cannot distribute the force over the same are that a 3" belt can, meaning that your body feels this force over a more focused area (focused force = bad). Finally, how many 2" 5/6 points belts do you really see? They're actually harder to find. Most 2" belts are 4pt. So, as far as safety goes, once you have invested in a cage and a fixed back seat, you don't stand to save much money in an inferior belt that's not even legal outside of autocrossing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">isn't a 2" with sub going to be a lot safer than just using a stock belt. </TD></TR></TABLE>
I don't think there's going to be a whole lot of reliable research to answer this question, because the standard is 3" belts. And OEM belts have way more crash testing data than any of the harnesses.
Old Oct 10, 2003 | 11:55 PM
Reza.dc's Avatar
good points
Old Oct 16, 2003 | 08:20 AM
Outsane's Avatar
I got a set of the 4pt sparco clubman belts 2" (for $50)
the belts are made by TRW, who make OEM automotive parts.
I have to belive that this harness will be safer then the OEM, Because
1. there are now two shoulder straps. instead of one.
2. The amount of mounting points, and straps so the force can be distributed much better, to the car and around the body.
but still not as good as a 3" harness
Just my two cents.
pinoyk20
Honda S2000
30
Jun 11, 2007 09:20 AM
VeilSide_Mas
41
Sep 5, 2005 08:57 PM
msTEGGY
16
Sep 30, 2004 09:34 PM
Smeeg Heed
Mar 24, 2004 02:36 PM
davidnyc
Jun 24, 2001 06:15 AM
