Metal shims needed on brake pads?
Old Oct 8, 2003 | 11:59 PM
mickey513's Avatar
Default Metal shims needed on brake pads?
I changed the rear brakes pads on my Integra week. However, during the process of removing the brake pads, I damaged the metal shims on one of the old pads and couldn't reused them on the new pads. The new pads didn't come with new shims. Anyway, I installed one of side the brakes w/o the metal shims. Is this OK??????????????
Old Oct 9, 2003 | 01:02 AM
PoW LSvtec's Avatar
Default Re: Metal shims needed on brake pads? (mickey513)
without the metal shims and grease, they may squeak
Old Oct 9, 2003 | 09:18 AM
mickey513's Avatar
Default Re: Metal shims needed on brake pads? (PoW LSvtec)
No sqeek.
Old Oct 9, 2003 | 09:24 AM
wcsinx's Avatar
Nah, you don't need them, but your brakes might squeal a little (more). If so, just get some high temp brake silicone (I think the Permatex version is called "Disk Brake Quiet" or something like that) and make a layer of that stuff between the pistons and pads ... nice and quiet.
Old Oct 9, 2003 | 10:22 AM
Rory Breaker's Avatar
Like they say, they arent necessary. I am not running them, and my brakes can get pretty squeaky sometimes. I will put some on next time, but if you damaged one and cant reuse it, I wouldnt worry about it.
Old Oct 9, 2003 | 10:28 AM
InTeGrA_bLazEd's Avatar
Default Re: Metal shims needed on brake pads? (newgsrdriver)
can someone show me a pic of the metal shim please?
Old Oct 9, 2003 | 02:18 PM
mickey513's Avatar
Yeah, I installed the pads with only one side having the shims. The car brakes fine & thanks for the help everyone.
Just a word of advice to people thinking about doin the rear brakes, they are a lot harder then the fronts. The fronts were a piece of cake but the rear were such a pain in the ***. No wonder shops more for the rear then the front brake jobs.......
Old Nov 10, 2018 | 08:22 AM
Alainlepain's Avatar
Old Nov 10, 2018 | 04:29 PM
zeroptzero's Avatar
For some reason my rear pads had fitment issues and I left the shims off as that was the only way I could get the to fit, never had a squeak. I ran spoon front brakes on my S2000 for years without shims and never had a squeak, my new wildwood big brakes don't use shims on their pads, should be fine. I do lube the sides of all my pads and the piston contact surfaces, you do need to use proper lube.
Old Nov 12, 2018 | 09:21 PM
MotorMouth93's Avatar
10 Year Member
That is not a picture of brake pad shims.
Old Nov 12, 2018 | 10:13 PM
Jimmy's Avatar
Global Moderator
Originally Posted by Alainlepain
These appear to be brake pad retaining clips, not sure what to call them. (They hold the pad in place) Definitely not the shims the OP is talking about. I’ve ran without shims for years and I’m fine without them.
Old Nov 16, 2018 | 03:38 PM
I am sorry I though it was that..
So can you show us then a picture example?
Thank you
Old Nov 16, 2018 | 03:56 PM
zeroptzero's Avatar
my ebc greenstuff pads had a terrible fitment on the rear brakes , the only way I could get them to fit was to run them without retainer clips, I always have fitment issues with EBC pads on Hondas for some reason. I didn't have an issue by not running the retainer clips, still worked fine, no noise or anything. I don't recommend it but it can still work.
jlowellintegra
Dec 23, 2010 09:46 PM
AMG
13
Aug 18, 2004 09:03 AM
aziz93
Nov 25, 2003 06:25 AM
InTeGrA_bLazEd
Oct 14, 2003 12:47 AM
OEMaccord
13
Sep 20, 2002 11:08 AM
