QUESTION QUESTION CRX JDM
Old Oct 8, 2003 | 07:06 PM
risiah05's Avatar
Default QUESTION QUESTION CRX JDM
will I need the jdm radiator support for the front end conversion? will it even fit? or can i use the stock one from the USDM? on the headlights am i able to use the USDM corner lamps?..
Old Oct 8, 2003 | 08:01 PM
phan's Avatar
Default Re: QUESTION QUESTION CRX JDM (risiah05)
no you will not need the jdm radiator support...you will have to move your latch down a bit to close and lock the hood in place though. on the headlights, you can use 90-91 corners but the jdm corners only have one light socket (usdm has two).
trepteg
Oct 4, 2007 11:36 AM
spec:jdm
Jul 1, 2005 01:00 AM
deez nuts
41
Mar 24, 2004 06:21 PM
jet
Jul 1, 2002 08:44 PM
