Urgent!!! Car Won;t Start! Not ur typical question please help
Old Oct 8, 2003 | 02:32 PM
E46M3CB's Avatar
Default Urgent!!! Car Won;t Start! Not ur typical question please help
Please help!
https://honda-tech.com/zerothread?id=642554
Old Oct 8, 2003 | 03:06 PM
JimBlake's Avatar
Default Re: Urgent!!! Car Won;t Start! Not ur typical question please help (B18CDB8)
Well, if you've got NO compression in all 4 cylinders, you might want to check your timing belt...
Old Oct 8, 2003 | 03:09 PM
E46M3CB's Avatar
Default Re: Urgent!!! Car Won;t Start! Not ur typical question please help (JimBlake)
how do i test my timing if i can;t get the car to run at all?
Old Oct 8, 2003 | 04:12 PM
mmuller's Avatar
Mad Scientist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CDB8 &raquo;</TD></TR><TR><TD CLASS="quote">how do i test my timing if i can;t get the car to run at all?</TD></TR></TABLE>
check your timming belt, not ignition timming.
so let me get this straight, it was fine and all of a sudden you have no compression?
Old Oct 8, 2003 | 05:13 PM
E46M3CB's Avatar
Default Re: Urgent!!! Car Won;t Start! Not ur typical question please help (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
so let me get this straight, it was fine and all of a sudden you have no compression?</TD></TR></TABLE>
thas correct. eveyrthing running perfectly fine, shut off car took off dist and reinstalled with tegh msd blaster 2 coil and 6al started it back up and car wouldnt start
got tired of installation put it back to stock and car would still not start...
timing belt is fine
Old Oct 8, 2003 | 07:45 PM
vtecdamian's Avatar
1 check the actual compression tester on another car it may be bad
2-get cyl at tdc and put a compressor to the cyl with the compression tool....listen for air from t/b ..headers or breather on valve cover
3-check harness plugs make sure they arent mixed up...map/tps etc
4.....pray for the best
Old Oct 8, 2003 | 08:15 PM
spaceman's Avatar
you didnt put it back together correctly dood..go and redo it..you took the whole distributor out?you prbably turned the rotor and didnt know it or somethin,messed up your timing
junior_tm
Jun 1, 2010 07:57 PM
igo4bmx
Mar 2, 2007 06:39 PM
RockLee`
Oct 29, 2006 03:43 PM
CPT.PANDA
Feb 1, 2006 07:17 PM
1SiKDA8
Jun 13, 2005 01:38 PM
