ITR ABS 3 or 4 channel?
Old Oct 7, 2003 | 06:47 AM
Bnjmn's Avatar
Default ITR ABS 3 or 4 channel?
Is the ITR ABS 3 or 4 channel? Did it ever change from 3 to 4 channel?
Anyone know if/when any other Integras have a 4 channel?
Thanks
Ben
Old Oct 7, 2003 | 07:57 AM
sgT's Avatar
sgT
Default Re: ITR ABS 3 or 4 channel? (Bnjmn)
afaik they are all 3 channel
Old Oct 7, 2003 | 08:08 AM
Bnjmn's Avatar
Default Re: ITR ABS 3 or 4 channel? (sgT)
Does anyone have a '98 Helms handy? I'm away for work and the Helms isn't exactly portable.
Anyway, if you do...check it out for the a 4 channel setup if you can. In particular if the wiring supports four solenoids and if 4 solenoids are present or only 3. I think Honda changed it in 1998, at least on the GSR and 97+ ITR.
I searched the archives about this and found a post but it was never resolved.
Thanks
Ben
Old Oct 7, 2003 | 08:55 AM
Bbasso's Avatar
yes, 3 channel abs, the rear are tandem.
Old Oct 7, 2003 | 09:22 AM
Willard's Avatar
Default Re: ITR ABS 3 or 4 channel? (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">yes, 3 channel abs, the rear are tandem.</TD></TR></TABLE>
hrmm... me thought that the rears were independent.
[edit]
http://www.we-todd-did-racing....5NTQx
two in and four out.
Old Oct 7, 2003 | 09:45 AM
Bbasso's Avatar
Default Re: ITR ABS 3 or 4 channel? (Willard)
Wait a min!...
look what I found, could I be wrong?
https://honda-tech.com/zerothread?id=143207
Old Oct 7, 2003 | 09:47 AM
Bbasso's Avatar
ok I see.. I was getting nervous. it has 4 sensors to look for lock up but 3 channels to pulse the wheels
Old Oct 7, 2003 | 09:48 AM
Bnjmn's Avatar
I think it changed to a 4 channel for the '97 ITR and all 98+ Tegs. They all share the same ABS modulator according to acurautomotiveparts.com. Just hoping someone could confirm this...
I have a 2000 ITR ABS setup...I just the plugs/2 relays on the frame rail and I want to make sure that plugs from any 98+ Teg will be compatible with the 4 channel system...if it is 4 channel at all.
Thanks
Ben
Old Oct 7, 2003 | 09:58 AM
DutchITR1689's Avatar
It's 4 channel mechanically, but the ABS control unit is 3 channel (electrically).
The Control unit selects the channel with the lowest wheel speed (the 2 rear channels).
Old Oct 7, 2003 | 09:59 AM
Bnjmn's Avatar
Default Re: ITR ABS 3 or 4 channel? (DutchITR1689)
And it all suddenly makes sense....thanks. And that also means that any 98+ plugs will work so I'm all set.
Thanks again
Ben
Black R
Oct 24, 2012 06:22 AM
Jonathan_ED3
May 28, 2004 10:13 PM
mikeweb
Feb 24, 2004 12:27 AM
Boostage
Dec 10, 2003 04:25 PM
yaksplat
Aug 23, 2001 08:42 AM
