Quick Question for OIl
in the manual, an LS calls for 4 and a GSR calls for 4.2. regardless, you should always go with what the dipstick says. when i change mine, i usually pour almost 4 in then check the dipstick. if it needs more i will add it until its at the right level.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpteg »</TD></TR><TR><TD CLASS="quote">in the manual, an LS calls for 4 and a GSR calls for 4.2. regardless, you should always go with what the dipstick says. when i change mine, i usually pour almost 4 in then check the dipstick. if it needs more i will add it until its at the right level. </TD></TR></TABLE>
Thanx man, yea it's pretty common sense to just be checkin it, but i'm using Mobil 1 Syn, 4 quarts and when i checked the dipstick, it's calling for at least 1/4 to half a quart more.
