burnt ignition coil
Old Oct 6, 2003 | 09:43 PM
quarterkorean's Avatar
Default burnt ignition coil
i did a search already. i have a jdm b16 and the other day while driving my car shut off. i pulled over and when i pulled the dist cap off, the ignition coil was physically melted. my speedo isnt hooked up so ive been running w/o vtec for a while now. i cant think of what burnt it like that but i replaced it w/ another and it works fine now. i appreciate any responses.
-tom
Old Oct 6, 2003 | 09:46 PM
SC0TT's Avatar
They burn out, just happens with wear. Replace it and if it happens again, then look into it more.
Old Oct 6, 2003 | 09:53 PM
Default Re: (SC0TT)
yeah but ive never heard of them physically burn up like that. i mean i know they go bad, but usually they just... go bad, not char the inside of my dist.
Old Oct 6, 2003 | 10:20 PM
xvracing's Avatar
Default Re: (quarterkorean)
same thing happened to me, replaced it and it now works fine
Old Oct 7, 2003 | 01:50 AM
ImportsCRX's Avatar
Default Re: (xvracing)
yep, happened to me also.
Old Oct 16, 2003 | 02:09 PM
EG6[B16A1]'s Avatar
Default Re: (ImportsCRX)
hey I have some problems that I'm not sure of, maybe it can be a ingtion coil too...
well heres what is happening.
I own a first gen B16A
normaly my car will engage v-tec at 5500
but for some reason it now starts at 5000rpm and also I feels like I've lost so much power that I just sit there making noises for nothing.
also at times my car studders during v-tec zone
what can this be? coils??
I've replace my coils a year ago. but I've hear many stories about B16's being notorious with its distribltor.
also 2 weeks before any of this occured, I've added in some fuel injector cleaner, can that be the cause?? I've just replaced the fuel filter too, nothing change.
car still makes a weird vacum noise when I accelerate
thanks
Old Nov 8, 2003 | 08:00 PM
JCCOOL43's Avatar
Default Re: burnt ignition coil (quarterkorean)
happened to me too today and i replaced it
had to go to pep boys since i have work tommorow and they were the only ones open- cost me 53 bucks! jeez wonder if that's normal?
but hopefully i won't have anymore problems
Old Feb 29, 2004 | 05:46 PM
ironchef25's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quarterkorean &raquo;</TD></TR><TR><TD CLASS="quote">i did a search already. i have a jdm b16 and the other day while driving my car shut off. i pulled over and when i pulled the dist cap off, the ignition coil was physically melted. my speedo isnt hooked up so ive been running w/o vtec for a while now. i cant think of what burnt it like that but i replaced it w/ another and it works fine now. i appreciate any responses.
-tom</TD></TR></TABLE>
hey quarterkorean from what car did you get you ignition coil from? cause the same thing happend to me and i bought it from a 91 integra. seems to fit fine but for some reason the new one, i cant really hear vtec really good. only if i slam the gas. is this normal?? sorry to bring an old thread
Old Apr 16, 2004 | 05:47 AM
jyipdragon's Avatar
Hey can you tell me how to replace the ignition coil? I have a 1990 Integra and I just purchased an OEM coil. However when I open up my distributor and undo the screws for the coil ... I can't get to the 2 screws at the back of the cap.
Must I remove the rotor and full out the entire unit?
Is there anything special I need to watch out for?
Old Apr 16, 2004 | 05:48 AM
jyipdragon's Avatar
Hi,
I'll be great if you can reply to this post instead. I need detailed instructions on how to do this.
Old Apr 19, 2004 | 05:48 AM
ironchef25's Avatar
Default Re: burnt ignition coil (jyipdragon)
it should just pop in to place. screw the two wires and your done.
JoHA
Jun 9, 2008 07:50 AM
obuhmyuh
May 19, 2008 01:21 AM
TypeSLO
Feb 27, 2007 03:52 PM
Nerologic
Jan 29, 2007 03:56 PM
96b18c
Dec 28, 2004 11:31 AM
