R died out while driving, this happen to anyone else??
Old Aug 28, 2001 | 08:18 PM
Dan's Avatar
Dan
Default R died out while driving, this happen to anyone else??
Goin to work and all of a sudden my R dies out. NO engine check light, Full tank of gas. I turn the key and the engine cranks. Fuses in engine bay okay. Car would not start like if I were to pull the ECU fuse. I towed it to the dealer and got a rental and went to work. Dealer calls me 30 miutes later and the car started, but they did not do a thing. Car is STOCK. I do have an Alpine alarm, but it will not arm if the car is started. Dealer notice that the alarm is aftermarket and would NOT run any checks. about 4 weeks back I left the car in the garage for 3 days cuz I went to Vegas and when I tried to start it, car cranked but would not start. I had to turn the key to the let the fuel pump prime for a minute then the car started just fine. I think its the full pump, but not sure.
Old Aug 28, 2001 | 08:21 PM
Chris's Avatar
Default Re: R died out while driving, this happen to anyone else?? (ITR 1413)
Loose battery cable.
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: R died out while driving, this happen to anyone else?? (Chris)
did any of the accesories work? this was a topic awhile back...how is ur ignition coil?
Old Aug 28, 2001 | 08:22 PM
BDiddy's Avatar
only one way to find out. Change the pump. But im with chris. Check the cables first
Old Aug 28, 2001 | 08:23 PM
H-PIMP's Avatar
Default Re: R died out while driving, this happen to anyone else?? (B-DIDDYR2K)
Fuel pump ground?
Old Aug 28, 2001 | 09:03 PM
Dan's Avatar
Dan
Accessories work and battery cables are fine. If I remember correclty, when the car began to sputter I hit the gas and npthing happened. The guy that put in the alarm had it wired for an ignition kill. He came out and disconnected that, just incase, but like I said before the alarm will NOT arm/activate if the car is on.
Dan's Avatar
Dan
Default Re: R died out while driving, this happen to anyone else?? (Rguy)
How would I check the ignition coil?
Old Aug 28, 2001 | 09:08 PM
Dan's Avatar
Dan
Fuel filter??
Old Aug 28, 2001 | 09:14 PM
Wet Nudl's Avatar
New User
If the engine cranks and does not start, 9 ou of 10 is your fuel pump.. Unless Honda wants to get sue this time with their bad ignition recall (happened back in early 90's with their Civics), they should've gotten this worked out.
Old Aug 28, 2001 | 11:20 PM
Sa-Da-Teh's Avatar
New User
I second the fuel filter. My cousin's integra did the same thing. Changed the fuel filter and no problems since.
jws42292
Mar 1, 2019 05:01 AM
JdmRex805
19
Nov 20, 2014 05:23 PM
NOUNOURS-EP3-2002
May 14, 2008 03:56 PM
22boost
May 13, 2006 04:44 AM
