ls crank b18c5 block, what will happen
Old Oct 6, 2003 | 08:56 PM
delux247's Avatar
Default ls crank b18c5 block, what will happen
question:
if i put a ls crankshaft in a b18c5 block will it stroke it any ???
Old Oct 6, 2003 | 09:54 PM
CLvtecGSR98's Avatar
Default Re: ls crank b18c5 block, what will happen (egcivicturbo)
in short terms...minorly.... yes...
stroke of b18c1 and b18c5- 87.2mm
compared to
stroke of b18b crank- 89.0mm
difference 1.7mm...lower r/s ratio of
but...
Rule!!!! Any B series rod will fit any B series crank, EXCEPT the B18C's and B16B (CTR) ( etc.... "R" family: ITR, GSR, CTR).
so have fun trying to machine th c5 rods to that crank....
also learn this formula- Block Deck Height = (Stroke/2) + Rod Length + Compression Height + Stock Deck Clearance
Old Oct 6, 2003 | 09:58 PM
mmuller's Avatar
Mad Scientist
yes it'll be like a ls/vtec but better.
89mm stroke.
Old Oct 7, 2003 | 04:36 PM
delux247's Avatar
Default Re: ls crank b18c5 block, what will happen (mmuller)
ok then another question who has done this and do they think the benifited from it?
and what was involved?
Old Oct 7, 2003 | 05:17 PM
pro1342's Avatar
Don't bother. Stick with the ITR crank.
Old Oct 7, 2003 | 06:45 PM
AzG35's Avatar
Default Re: ls crank b18c5 block, what will happen (pro1342)
Basically it would be an LS/VTEC with oil squirters and the oil passages in the correct locations. You may have to bend the oil squirters since the crank has a longer stroke and may tap them a bit.
Old Jan 3, 2009 | 08:37 AM
heel_touge's Avatar
back up because search ****ING SUCKS and i cant find enough info on this.
so.... i would need to use aftermarket or LS rods on this setup?
and is it even worth the extra torque?
Lil_savage
Feb 20, 2019 03:19 AM
PhatwhipsJDMkits
Mar 30, 2012 06:27 AM
joedeezy
Oct 18, 2008 02:53 PM
BlakeJ53
Sep 4, 2007 03:59 AM
gmacarize
Jul 26, 2006 08:16 PM
