broken oil pump picture, all motor ls/vtec
Old Oct 6, 2003 | 06:04 PM
shant's Avatar
Default broken oil pump picture, all motor ls/vtec edelbrock IM Dyno
If anyone is interested the oil pump went, its broken in about 20 pieces.
I was able to get 2 passes before the oil pump went both were 12.3 @ 106 mph and the last pass where the oil pump went was 13.2 @ 100 mph. after i shifted to 4th gear i noticed that the oil pressure warning light was on and i turned off the motor right away.
Is it true that if the oil light comes on while full throttle and high rpm the damage is already done and its too late? I have checked all the bearings and I dont see any problems. I will check the cams and cam caps later tomorrow to see if there is any damage up there.
Btw. I also tried the edelbrock intake manifold for this past weekend and I dynoed a tuned 190whp and 128wtq compared to 197whp and 137wtq with the stock type R manifold, the loss of power and torque in the lower rpm range was far greater than the peak losse. I'm dissapointed with the edelbrock intake manifold. I was aware that I would lose power before 7000rpm, unfortunatly it lost a **** load of power everywhere, piece of junk. I guess ill keep the manifold for when I have a turbo CRV as a tow vehicle later in life.
_______
Modified by shant at 10:34 PM 10/6/2003
Old Oct 6, 2003 | 06:05 PM
SOHCArchangel's Avatar
Default Re: broken oil pump picture, all motor ls/vtec (shant)
thats what sintered metal does
Old Oct 6, 2003 | 06:28 PM
eg6h8k's Avatar
Default Re: broken oil pump picture, all motor ls/vtec (SOHCArchangel)
there ya go..
damn was this on a OEM honda pump..?
Old Oct 6, 2003 | 06:39 PM
shant's Avatar
Default Re: broken oil pump picture, all motor ls/vtec (eg6h8k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6h8k &raquo;</TD></TR><TR><TD CLASS="quote">
there ya go..
damn was this on a OEM honda pump..?</TD></TR></TABLE>
yes oem pump
Old Oct 6, 2003 | 06:44 PM
zc911's Avatar
sorry to hear man
The oil light come son at some rediculsly low number i think, somthing like 5psi
Thats why i run an oil pressure gauge
Old Oct 6, 2003 | 08:39 PM
1 2 NV's Avatar
Default Re: broken oil pump picture, all motor ls/vtec edelbrock IM Dyno (shant)
sorry to hear that shant. ive been lucky, my motors been running flawless for 2 seasons now and still ran 12.13 on sunday o yeah im a first time engine builder too.
Old Oct 6, 2003 | 08:45 PM
evilxkid's Avatar
Default Re: broken oil pump picture, all motor ls/vtec edelbrock IM Dyno (1 2 NV)
that sucks man, get well soon
Old Oct 7, 2003 | 12:18 AM
aeolus's Avatar
Default Re: broken oil pump picture, all motor ls/vtec edelbrock IM Dyno (evilxkid)
Were you using a lightweight crank pulley??
Old Oct 7, 2003 | 01:17 AM
kwik93si's Avatar
Default Re: broken oil pump picture, all motor ls/vtec edelbrock IM Dyno (aeolus)
damn shant, that really sucks...i hope that nothin too bad happened to the motor.
Old Oct 7, 2003 | 06:07 AM
shant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeolus &raquo;</TD></TR><TR><TD CLASS="quote">Were you using a lightweight crank pulley??</TD></TR></TABLE>
yes i was using a light weight crank pully, it does not have a harmonic balancer.
but also last time at the track my flywheel came loose, so that might have damaged it before also.
Old Oct 7, 2003 | 10:59 PM
jdmcivicferio's Avatar
sounds like you over reved you oil pump gear, the stock oil pump gear can generally only handle up to 8000rpm, how high were you reving? either way I would switch to a pro-drive one.
Old Oct 8, 2003 | 04:55 AM
1 2 NV's Avatar
Default Re: broken oil pump picture, all motor ls/vtec edelbrock IM Dyno (jdmcivicferio)
ive never heard of a overrevved oil pump. sounds like u got ur info from fast and the furious.
how bout u show me some info about overrevved oil pumps breaking and when i tear down my motor ill show u a oil pump that doesnt see anything under 8k for the last 2 yrs. its the shockload of the launch that breaks oil pump gears.
Old Oct 8, 2003 | 05:00 AM
.y2a.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">ive never heard of a overrevved oil pump. sounds like u got ur info from fast and the furious.
are you still using a stock VTEC oil pump?
Old Oct 8, 2003 | 05:02 AM
1 2 NV's Avatar
Default Re: broken oil pump picture, all motor ls/vtec edelbrock IM Dyno (.y2a.)
of course i am.
Old Oct 8, 2003 | 05:12 AM
.y2a.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">of course i am.</TD></TR></TABLE>
might be some useful info in this old post re lightweight UR pulley's causing the failure.... your thoughts?
https://honda-tech.com/zerothread?id=641221
Old Oct 8, 2003 | 05:17 AM
1 2 NV's Avatar
i read the link, its a tough call, ive seen posts about the subject several times and i see both sides of the story, which is true and which isnt?? that i cant answer. i use a CTR crank pulley which is pretty light and have had no issues. other than that its up to u to decide.
Old Oct 8, 2003 | 05:20 AM
.y2a.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">i read the link, its a tough call, ive seen posts about the subject several times and i see both sides of the story, which is true and which isnt?? that i cant answer. i use a CTR crank pulley which is pretty light and have had no issues. other than that its up to u to decide.</TD></TR></TABLE>
thanx... I'll pass the info to Shant.
TypeRod
Sep 7, 2011 08:48 PM
99problemssss
Mar 6, 2006 07:17 AM
authority1
Apr 9, 2005 06:11 AM
Nextelbuddy
Jan 10, 2004 10:32 PM
Lei Siew Long
Apr 17, 2002 08:54 PM
