no CEL when key is turned to accessory
fuel pump does not prime
no cel on dash
have changed
ecu's
main relay
distributors
battery
altnerator
what else can i do?? anyone?
no cel on dash
have changed
ecu's
main relay
distributors
battery
altnerator
yes.....when turned to the on posistion....even when you turn it over....
turns over....just no spark and no fuel....
everything is connected....
Main relay maybe? Someone just suggested that in another thread.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yebabee »</TD></TR><TR><TD CLASS="quote">its only 50 bucks or you can resolder it for free. turn the key over to accessory and listen for the fuel pump click and the check engine light will go off. if it doesn't do both of these then it is the main relay. heres how to do it:
http://www.markl.f9.co.uk/howt...y.htm</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matt_sb2000 »</TD></TR><TR><TD CLASS="quote">Main relay maybe? Someone just suggested that in another thread.
he already changed the main relay...and when my main relay went bad, all the lights came on just the fuel pump didnt prime...chad check all the wiring to the fuel pump and top of the fuel tank under rear seats and fuses...maybe you have a short somewhere?
rick_rabies
11
May 22, 2011 03:23 PM
