why go all motor?
Old Oct 6, 2003 | 12:52 PM
h22a193's Avatar
Default why go all motor?
why go all motor? i will have to make the basic choice of go b18? all motor, and build it slightly, or b16 turbo and add onto the build. I your NA opinions what should I do. Every day driver here. Whats the best motor thats puts out the best numbers for NA?
Sorry bout the newdy q's but im a prelude guy and just want to get into the b loving fun!
Old Oct 6, 2003 | 01:20 PM
631 Teggy's Avatar
Default Re: why go all motor? (h22a193)
Why go boost?
Turbo = $$$$$$$$$$$$$$$$
N/A = $$$$$$$$
Well thats at first... If you get really into n/a then this would be the case...
Turbo = $$$$$$$$$$$$$$$$$$$$
N/A = $$$$$$$$$$$$$$$$$$$$
lol, so i guess n/a cuz it's easier to get into, and cuz it's more fun making an n/a 4 banger run 12's then making a turbo 4 banger run 12's...
Thats my opinion... Feel free to condradict... Everyone has their own reasons...
Old Oct 6, 2003 | 01:23 PM
justBLZE's Avatar
Chopper 2 Hopper
Default Re: why go all motor? (631 Teggy)
Because no blow off valve sound can compare with vtec at 9500 RPM
For real tho, both NA and Boost are fun, its really up to you which way you want to go, I prefer sleeper type of cars so I choose allmotor, one more thing.. no boost lag.
Old Oct 6, 2003 | 02:12 PM
h22a193's Avatar
what does it take to make a motor turn 9500 rpm, ^ im like you guys i like all motor better, I want a HIGH revving motor that still makes power at that high rpm. What motor would you guys recommend for this, and still put down awsome numbers?
Old Oct 6, 2003 | 02:23 PM
chris@allmotor.net's Avatar
Default Re: (h22a193)
id recommend a LS vtec or a GSR motor....fully built to rev that high.
Old Oct 6, 2003 | 03:32 PM
BolivianDc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a193 &raquo;</TD></TR><TR><TD CLASS="quote">why go all motor?!</TD></TR></TABLE>
because you don't want a high jolt of tq on a FF car midway through a turn
and because NA is Better!
Old Oct 6, 2003 | 03:58 PM
B3AS's Avatar
all motor is great for the sleeper factor. from the outside what seems like a single cam vtec could really be a built GSR motor. no BOV sound and no front mount giving things away. plus u can gradually build an all motor set up over time. turbo is all at once.
a b16 is a cheap way to rev to 9500 and then some. get some good cams, titanium valve springs and retainers, and u can handle really high revs with a setup like that. make sure ur getting enough fuel too.
Old Oct 6, 2003 | 04:58 PM
JD Milan's Avatar
Default Re: why go all motor? (Love2race)
personality, its fun, harder to make power but it is mostly a personal thing..
Old Oct 6, 2003 | 05:28 PM
Default Re: why go all motor? (JD Milan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JD Milan &raquo;</TD></TR><TR><TD CLASS="quote">but it is mostly a personal thing..</TD></TR></TABLE>
agreed, if it was all about time slips, i would have gone turbo
Old Oct 6, 2003 | 07:01 PM
Eyes Only's Avatar
Default Re: why go all motor? (Bolivianstrtwpn)
cause it is fun to hand people their *** on a silver platter and then u can tear your set up back down and build up with better parts for better # when new **** comes out
Old Oct 6, 2003 | 07:39 PM
GokuSSJ4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">Why go boost?
N/A = $$$$$$$$
lol true , but if you have the money at once its even more fun . out of both b18c1 is the best choice and you can boost later on if you choose to go that route . but all motor = no lag ..
Old Oct 6, 2003 | 07:41 PM
dfoxengr's Avatar
Default Re: why go all motor? (tommySI)
preference
Old Oct 6, 2003 | 08:40 PM
StorminMatt's Avatar
I see turbos as being a crutch. Take the Silvia and Skyline, for instance. If neither of these cars had turbos, they would be slugs of the worst kind. How much power could you possibly get for an SR20DE or a (hypothetical) RB26DE? Not enough to make those heavy cars go too fast. Because of this, going allmotor gives your car a certain credibility that turbocharging never will. If you are turbocharged, the domestic crowd will always think that you are only fast because you are turbocharged (and that you would be slow if you weren't). Suck people take it MUCH more seriously if you can run fast in a four-banger WITHOUT the help of forced induction.
Old Oct 7, 2003 | 06:08 AM
Default Re: why go all motor? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">I see turbos as being a crutch. Take the Silvia and Skyline, for instance. If neither of these cars had turbos, they would be slugs of the worst kind. How much power could you possibly get for an SR20DE or a (hypothetical) RB26DE? Not enough to make those heavy cars go too fast. Because of this, going allmotor gives your car a certain credibility that turbocharging never will. If you are turbocharged, the domestic crowd will always think that you are only fast because you are turbocharged (and that you would be slow if you weren't). Suck people take it MUCH more seriously if you can run fast in a four-banger WITHOUT the help of forced induction.</TD></TR></TABLE>
That's true about the nissans, but some cars were built with turbocharging in mind and others were built with no FI in mind. Look at a WRX, there blocks are monsters when it comes to turbocharging, you don't need to rebuild for strength even after some turbo upgrades. Being NA is fun, a way to look at it is getting the most power out of 0psi
but this is getting too GDD now, and i don't want Mods who are on a rampage to substract points, so ill just let this be.
Old Oct 7, 2003 | 06:41 AM
Lsos's Avatar
StorminMatt, I see where you're soming from. Nevertheless, if all one wants is power then you can't deny that turbo is the most cost/weight effective way of making large amounts of it. It might not command the same respect or "credibility", but not everyone is about that.
I personally prefer the sound of high rpms over turbo. However, given the choice between two motors, the NA making 200whp and the turbo 300whp....I still really don't know what I want to do, but sometimes you have to push emotional attachments and social values aside for the logical choice.
Old Oct 7, 2003 | 07:49 AM
SICKSOLSI's Avatar
Default Re: why go all motor? (Lsos)
For some reason I have always seen turbo as kinda cheating
Old Oct 7, 2003 | 08:30 AM
1_bad_EF's Avatar
Default Re: why go all motor? (95excoupeMT)
i like "natural aspirated" cuz its fun to see the look on ppl's faces when you take it 9.5K++.
And when you tell the humbled owner of a 99 Ws-6 that you didnt hear a BOV cuz I dont got one.
Then they call you on Nawzz, and you tell them, "go, ahead, look for it."
Those are pricless facial expressions that equal "respect."
Old Oct 7, 2003 | 10:05 AM
laughinxxx's Avatar
New User
Default Re: why go all motor? (1_bad_EF)
Because you can tell them it is just i/h/e and they can't prove a damn thing.
Old Oct 7, 2003 | 10:34 AM
md23vtec's Avatar
Default Re: why go all motor? (laughinxxx)
very true and when they think they finally have your car figured out spray it
shibikku95
23
Jun 30, 2006 06:00 PM
vpower
Jun 8, 2006 08:34 PM
CRX_Type_R
Nov 19, 2004 10:49 PM
redluder
Jun 29, 2002 02:19 PM
ITR1071
May 20, 2002 10:01 AM
