ecu/v-afc debate
Old Oct 6, 2003 | 11:28 AM
-slow ej-'s Avatar
Default ecu/v-afc debate
i was wonderin...if u had a choice of gettin a apexi v-afc vtec controller or a pr3 ecu to activate your vtec what would everyone choose?
Old Oct 6, 2003 | 11:32 AM
EL Vap133's Avatar
Default Re: ecu/v-afc debate (-RsINtEg-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -RsINtEg- &raquo;</TD></TR><TR><TD CLASS="quote">i was wonderin...if u had a choice of gettin a apexi v-afc vtec controller or a pr3 ecu to activate your vtec what would everyone choose?</TD></TR></TABLE>
What do you mean?
Old Oct 6, 2003 | 11:58 AM
-slow ej-'s Avatar
Default Re: ecu/v-afc debate (EVIL_Vap133)
ok...i recnetly got a motor...(d16z6) and im gonna be driving it without vtec...using my pm6 ecu a friend of myne told me in order to activate/hook up vtec to run i should get a p28 or a obd-0 pr3...now what i ment was if i were to stay with the pm6 and get the v-afc is it better or should i just go and get a pr3 (did that make sense?)
Old Oct 6, 2003 | 01:27 PM
ScottEK's Avatar
PR3 is made to run a DOHC engine, will a VAFC even activate without a V-IN signal?
Old Oct 6, 2003 | 02:08 PM
SC0TT's Avatar
Default Re: ecu/v-afc debate (beta13)
Just finished a d16z6 swap in a 89 dx hatch. Used a pg7 ecu and a VAFC to activate vtec, works really well. No problems.
Just run a wire off the vtec solenoid to the pink wire on the VAFC harness, thats all. Dont need to worry about the VTM/vtec pressure signal or running the vtec solenoid into the ecu
DGAF
Jul 14, 2005 06:07 AM
jaybsmooth
Nov 5, 2004 06:45 PM
Turbo Powa
Apr 8, 2003 06:07 PM
EJK
Apr 14, 2002 12:55 PM
